You guys talking about replacing the truck under 100k... Come on its not even broke in yetsent from my truck in a field
All my trucks I've had over 100k were definatley broken in
Trade in your current truck or just addition to the family?
Sent while drinkin' a cold one...
My 3 trucks combined aren't worth anything here so no. I will be selling my 03 because it annoys me lol. Its clean, pretty low mile(115000 miles) so it will move quick if I price it around 6-7k. My buddy might buy it to replace his rotting away 01 Sierra half ton. Plus then he has a truck better suited to pull his car trailer.
Sent from my SGH-I747M using Tapatalk
Edited by Badass69
I have a bad back. The discs above and below my bottom vertebrae are shot so it wiggles around instead of moving with the rest of my back. So I use the horse trailer since its low to the ground
Sent from my DROID X2 using Xparent Red Tapatalk 2
I hear you on the bad back... My discs are bad as well.
Droid x2... that was 4 phones ago for me
Yea because its over 100k
Agree but there is a still value in the truck to use towards a new one. Sold my 2000 back in 09 for 13K
Ryan
The 60e just blew the tranny pump. FML
Can't catch a break can ya bud
Sent from my LG-D800 using Tapatalk
Nope guess not. I guess that's what I get for getting a new quad today. Oh well it will be covered one last time under warranty. Or I'll just get a better built tranny. Any recommendations??
Anyone heard any good things about performabuilt transmissions? They have some good reviews on the ls1 website, but those were from like 08. Not sure if their quality has changed
Its really not at all. Then no more 4L60E bs ever again.
I feel like a 4l80 would be a bit more work on a 4x4. Tons of parts you'd have to hunt down.
Everyone talks about Finish Line trannys. I've never used one. Around here everyone uses Jasper's. They cost more but carry a 100,000 mile warranty.
This is coming from 4 WD experience but whatever lol. You guys can all do lifts, gears, engine performance ad ons but can't swap a tranny.... lol.
Whatever suits your fancy. Its just a suggestion. I have no input on 60e's as they are a waste of time IMO.
Edited by Badass69
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
