Also it is only one day a week.
Sent from my SM-N900V using Tapatalk
Gone mine back from the dealer. New throttle position sensor and some new ECM programming. Couldn't tell if there was a difference in response but I only had it stock for maybe 10 miles. Then I got home and re-loaded the tune. :D
You mean your warranty wasnt voided for having a tune ??? :lol:
Well I took it off because part of the TPS replacement is a reflash.
But they can still see you have a tune :lol:Ryan
That has to mean. Your warranty is voided hahaRyan
I changed the washer reservoir. That job sucks. It isnt hard, I just dont like having to pull the battery out.
Nah. I like my note 3, but I do miss having a smaller phone. And you dont want to know what I had to go through to get my name already. Sent from my SM-N900V using Tapatalk
10seconds in the user CP? That's how I removed 325is
More than that had to happen for mine. Not something I want to announce. If you have a question about it pm me. I needed admin help for mine
Did that a couple months ago to mine. Not hard but I broke the hard line going to the tank. Luckily the auto parts store got one for me the next day
Sent while drinkin' a cold one...
Finally sprayed it off only for my sexy tires to fling garbage all over it while leaving. And i put 50$ down on a 42" led light bar
Happy happy happy
sent from my truck in a field
Edited by SarahsGMC
My friend Allen and I took his 2014 to the drag strip for the nostalgia drags. I bought an AC Delco light up sign at the swap
Pics
Dont have any. Its boxed up in the truck. And im watching thr nitro cars crank up
Yea Chris pics of the light. Sounds cool!
Got my shine on today
Ryan
If we head back out to the truck I will get some. The huy wanted $275, but Allen got him down to $250. I dont like haggling with these people because I come off as an ****
No hurry whenever you have a chance
Ryan
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
