Traded in the Callaway today. Mixed emotions. I'll have it for a few more days as my car is on the rail now and transport tomorrow or Wednesday. Excited about the new SS, runs and drives amazingly well. Also sad to see the Callaway go. Great truck, surprised a lot of people (on closed courses). And now I'm on to another sleeper. Drove the tester by a buddy on Saturday and he thought it was a Malibu SS until I lit up the back tires. May have some parts for sale after the swap, supercharger not included(sorry Chris).
Congratulations. I'm officially jealous lol!
I think the mods are with me on this Jon: Pics on delivery or ban!! :)
But I hope you stick around, we'd miss you.
Edited by kstruckcountry
Im about to ban for just selling the Callaway
Sent from my SM-N900V using Tapatalk
Phantom Black Metallic
The SS is a sweet car, hope to get one eventually, that or find a gxp g8.
Good luck finding one. I've looked for one a couple months ago just for shits and giggles and only found like 4 for sale in the US
Sent while drinkin' a cold one...
Good luck finding one. I've looked for one a couple months ago just for shits and giggles and only found like 4 for sale in the US Sent while drinkin' a cold one...
yeah they are definitely few and far between, people with them are like me, I would get it and probably not let it go, lol.
Removed nerf bars:
So I can take em in for sandblast and powder coating. Factory stuff sucked. Also going to redo my rocker panels cause i did a 5 minute job before. Not sure why i just didn't take the time to get it right the first time:
May also paint the frame since the truck will be down for at least another 3 weeks or so. Also going to paint the torsion bars too
Drove it around the yard, and did a few burnouts. :driving:
When are you going to become Daryl C1500?
When are you going to become Daryl C1500? Sent from my SM-N900V using Tapatalk
IDK? I was just thinking of changing it, but I wasn't sure if I liked it or not.
Do it
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
