Turn it off lol sent from my truck in a field
Not sure how to turn off the setting for the beep. Don't really mess around with it except for washing clothes haha. And most of the time I hear it while laying in bed trying to fall asleep lol
Sold the rims. Getting some used 315 70r16s put on the stock wheels for now
Sent from my LG-D800 using Tapatalk
I hooked up my my little brown trailer again.
Drove to the Ambassador bridge for nothing. Apparently I needed a work permit to get into Windsor for this job and we don't have one. Oops.
That's the blue one in Detroit that looks 1000 years old?
I remember seeing that thing and wondering if they had ever heard of paint, it was rusted bad when I was there. Then I drove through the "bad" parts of Detroit, and realized, no, they have never heard of paint. And before anyone start yapping about poverty, the neighborhood I drove through was filled with expensive cars parked in front of shantys.
Edited by SnakeEyes
315/70r16 wrangler at/s. Cost me 60 bucks
That's the one. It's privately owned by a greedy **** who failed to build the promised ramps from the bridge to I75. Currently to get to/from I75 you take surface streets... right past gas stations and stores he owns.
315/70r16 wrangler at/s. Cost me 60 bucksma7eguby.jpgypa3e2a4.jpgSent from my LG-D800 using Tapatalk
Nice score! Probably get 30k out of those at least
Thanks. They even still have the nipples on the side
Tomorrow using it as the second vehicle to get a ride back from dropping off corolla for a new windshield.
Strange, one place I have gone to before is charging $333. They will come to my house for no extra charge. I am going to a cheaper place that is charging $303, they only do it at their shop. The place charging $333 took under an hour to do the Tahoe.
The place I'm going tomorrow wants 3 hours for the corolla.
Huh?
Huh?
You save $30 cause it takes longer, at least that's what it sounds like. Hopefully they are trained to do the job properly, and pray it wont leak after their done lol
8y7yje9u.jpg This is where I went today :jester:
Took it out to drop off some used printer cartridges at the girls school. They get money for them. They can use all that they can get.
Changed oil and air filters in my mom's vehicles for her. I think when I moved out so did general cleanliness and care for vehicles.
Picked up new u joints for my pickup. Priced a fuel pump too, ahhhh expensive.
Gazed at its sexines and an old woman got pissed today with me at work
She randomly says this to me as it's warming up in the parking lot after work.
Old lady- why do you need such a big loud bright truck it's so pointless for a girl.
Me- why are you such a nosy annoying b!ch?
I then hopped up in my big bright loud annoying pickup and took off... can't wait to hear about it tomorrow.
Edited by SarahsGMC
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 575 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
