Washed mine today, added some air to the Grabbers to bring them up with this cold weather - they were getting close to 25 psi, most around 27, brought them up to 30. Then I drove to the store to get a few things.
Took the truck in for mudflaps, box liner, and black bow ties.
Before:
After:
Next up is getting rid of those damn dealer decals, rims and tires.
Before:
After:
If I ever order a vehicle I will tell the dealer that if I walk up when it arrives and see one of their logos on the paint that I will turn around and walk back off
I hauled a friend's old blazer out to the ORV area. It was heavy, and very sketchy to haul in the snow. Good time watching the "hulk" buggy and some others climb some rough hills in the snow.
Gassed it up and drove in some snow
Ryan
Cranked torsion bars and broke a bolt so i only got 3/4 a lift in front but it sits better just a tad under 7" in front and I'm 7.5" in rear looks better
Did you jack up the front end?
I changed out a taillight bulb, it had started to melt the lens. Hoping the bulb was the issue but if it keeps melting I guess I'll have to get a new housing.
715470D3-24E6-4500-BE56-79EC2DF03145_zps
Took mine through the car wash because it was absolutley filthy and i don't have the time to wash it by hand right now.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
