Got stuck behind a Dodge Ram with a stupid driver while driving downtown. Truck looked nice but then gunned it & it sounded like a crotch rocket motorcycle with a cold. Engine would hesistate & shifted weird.
Drove 150 miles between interviews and apartment hunting today. Truck loves doing 70+
Mines the opposite due to the steep gearing. Anything over 80 and I start to get driveline vibration haha oh well traffic around here is so bad most of the time your lucky to see 70
Sent while in 'Murica...
I live in Charlottesville VA and I am looking to move to Waynesboro. I64 and I81 are alwayz stupid fast speeds. Hell, even the semis are doing 75+ on that side of the mountain. The way my truck is geared, 315 with stock 373 gears, she is doing about 2k at 75mph. I too get a shake now at speed, between 62-66, goes away around 72-74 then starts back on the high side of 75. I think it because of the tires, I did not have the shake with my more aggressive Kelly tsr. My parents live in Alexandria area, I am up there at least twice a month, I know N VA traffic. It is horrible, horrible, horrible!
Thank you, I am hoping to hear back this Friday on either job. Crossing fingers man, I need a real job lol.
Drove home from vegas this morning. Feels great to be home
Order my new lift springs got a great discount it's awesome having inside guys :D
Worked on my trailer it's now ready for lights a floor and new rims/tires
And my shock is leaking.. gonna take it off and see how bad tomorrow.
Got to drive back & forth around the base today. Too many job to finish up & not enough Friday to get it done. Then I got to find out I work this weekend...oh yippie!
It's probably that bolt that holds the ebrake cable to the shock mount. Did it to my old shocks. Dug into the housing and blew out the shock. Thank goodness for the reverse design on the 5100 series Bilsteins, no more issues!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
