DC-2
I like them, I've wanted them since I had my last truck, but forking up that money right now doesn't seem too smart. Obviously it would be good for the future sets of tires because they will probably be cheaper than $300 a piece, plus the wheel cost is lower than a 20"
You know you want to. [emoji1]
I've looked at tire pricing, it's actually cheaper to buy my current tires (LT275/60R20) as compared to 33x12.5r18's. I attribute that to the width factor
Fixed a '06 Impala driver's seat. Only 90k miles. Thing was slammed all the way to the floorboards, and wouldn't move. It went back and forth, but wouldn't move up and down. Could hear & see the motors trying to move the seat, but they couldn't for some reason. Found out why once I got the seat yanked and dove in.
Seems whatever limiting device that's supposed to be on there failed, and caused both drive screws to bind up solid. Had to really put some muscle into a pair of vice grips to get the SOBs to move!
Worked on it in the back of my truck - had the front of the seat down on the tailgate, and the seat back resting on my tonneau cover, so I could work underneath it. See 1st pic.
Had to remove the drive cables (that was fun ... and getting them back in was even ... "funner"), & take apart the plastic gear housing, & remove the worm gear in order to relieve the tension, and be able to wrench the drive screws backward.
While I had it apart, I threw some J/D Corn Head grease in there - can't hurt. Threw some all over the drive screws too, although it's probably just going to collect sand and grit.
Was a complete pain in the ass. No surprise there. Can see in the pic how much room I had to get my 1/4" wrench in - could barely fit a finger in there. GM builds this stuff to be totally unserviceable. To that, GM can guess which finger I'm extending. :devil:
Maybe this will help someone out in the future, when their seats seize up solid too. I'm sure this applies to all their models in one variant or another.
Just FYI - there's a little piece that looks exactly like a watch battery that will fall out of there when you disassemble that little plastic gearbox. It goes right on top of, or under (depending on what side you're working on - can change orientation) the driven gear (the drive gear is the worm, the driven is attached to the drive screw). I don't have a good pic of it here, but you might be able to see it in some of them:
EDIT: Found a pic of the "watch battery" spacer I was talking about.
Edited by Jsdirt
Mine sat in the parents driveway today. It's been used non stop the past week. Probably going to use it and the trailer to haul away some scrap toward the end of the week.
Been detailing trucks since I came back from woodward I've got 4 vehicles booked this week
Sent from my SM-G925V using Tapatalk
Edited by SarahsGMC
Full time job now? I remember you used to work in a factory of some sort if I recall correctly
What's all involved in detailing a truck?
I had to run around to get things to put the stereo in the F150. My Sierra started overheating at a light.
Here is the finished radio
Got the rear brakes done
Ryan
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
