Yeah I've seen a few different brands suffer the same fate. My Toro 828 Powershift is one of them - scraper is gone, & it's cutting into the sheet metal now. That one is a '88. I've been through that thing front to back - all new shafts, bushings, belts, fresh paint (done the right way), found some decent original tires on eBay, and just went through the transmission I also bought off eBay when the original one spit a bearing right out of the case. Was lucky to find one when I needed it at a reasonable price - was froze solid when I got it - full to the brim with water that froze in the delivery truck. On the original, someone had attempted to weld the bearing area, and failed, apparently. Got that Toro for free from my buddy - he left it outside unused for 8 years. She's all back to her former glory. Only thing I haven't touched is the engine, aside from the ritual carb clean, thanks to MA's crap gasoline.
The bumper you saw is a '86 Grand Marquis. Bought that for the wife 14 years ago next month. She drives it 70 miles a day for 3 seasons a year. We've put over 170k on it so far. Doesn't burn a drop of oil, but has leaked since day one out the rear main, and timing cover. Reliable as a stone ax. I've done very little to this thing over the years. Love that car. Over 130k on the ball joints - did them in '05. The OEM starter just failed this year. 30 years! Last year I rebuilt the entire A/C system - that too was all OEM original. STILL on the original OEM fuel pump! If only my Silverado's pump would make it half that long ...
Only thing I don't love about the car is the quirky idle (Multi-port F.I.) - it's perfect some days, then erratic as hell others - and the slushbox transmission. Slow to shift, and has a SUPER tall overdrive that lugs the engine on any hill under 48 MPH.
Some day when the engine finally croaks, I'll do a long block, carb., and throw a built tranny in there. Will go another 30 years easy. :thumbs:
Some pics of the Toro:
Toro%20snowblower%20rebuild%20-%20paint%
Toro%20828%20transmission%20eBay%20clean
Toro%20snowblower%20rebuild_zpshgxvafqk.
Toro%20snowblower%20rebuild%204_zps8jfph
Toro%20snowblower%20rebuild%20-%20FINISH
I figured it was either a Grand Monkey or a Continental. Good deal. I love those old Box bodies. Do you hang out over on crownvic.net?
Adjusted my timing, fuel screws, and idle on the 86.. it's was way Otta whack
Sent from my SM-G925V using Tapatalk
Edited by SarahsGMC
Checked the voltage at my blower motor and every thing checked out. I replaced the resistor regardless b do to some corrosion on the cooling fins. Now it is a wait and see deal.
At the shop today on a sunday I repaired 2 AutoStart FOBs, a 2503 and an older 433A. These people couldn't believe that for 10 bucks they had their remote start working again....
Hoping you don't have any more issues. It's irritating when you have to replace the same part over and over again.
Whelp, just moved all the scrap metal out of the back of the useless turd I had in there for traction. Think I got 1.25 plowing seasons out of it. Wasn't expecting a driveline failure. Figured the frame would bust in 2 first.
Tried plowing the 7" of snow we got yesterday - 4x4 failed immediately. FIGURES!! :banghead: Got stuck everywhere. Then not 20 minutes later, I throw the clutch in to get ready to shift to reverse, and I hear PLINK! Pedal dropped like a rock. Friggin pile of crap!! :mad:
Was fun while it lasted. :rolleyes: Got it for free, and put $70 into it for a clutch line when I first got it. No loss, I guess. Should've sold it when it was useable and bought something better.
Pretty sad when a 800cc ATV shows you up as a "truck" ...
So I woke up today with a message from my mother saying I had a check there from Walmart. There was a class action lawsuit, and they finally settled it and mailed out checks this week. I worked there for 8 hours back in 2006. I did a day of training and that was it because my current job offered me more money to stay. Well it turns out this check is for $544! I didn't believe her until she sent me a picture of it. So it looks like I'm going to finally have my cluster redone in the truck.
I sure wish you weren't in the USA, I would love to redo your cluster. Sounds challenging. Yours is the one that stays on when it should turn off right? I did one 2 weeks ago that took me almost 10 days to find the cause. I realise shipping cross border is a hassle, so much for free trade right.......Getting one from Newfoundland this week with the same type of symptoms, shipping returned is only $40Cdn.
Edited by Coby7
I sure wish you weren't in the USA, I would love to redo your cluster. Sounds challenging. Yours is the one that stays on when it should turn off right? I did one 2 weeks ago that took me almost 10 days to find the cause. I realise shipping cross border is a hassle, so much for free trade right.......Getting one from Newfoundland this week with the same type of syptoms, shipping returned is only $40Cdn.
Actually there doesn't seem to be anything wrong with mine other than half the bulbs being blown out, but I want the whole thing rebuilt anyway. Probably going with blue needles as well, and also having them add a transmission temperature gauge.
I need to have mine replaced. I am growing tired of the LED lighting
What's wrong with the LEDs? I'm going with regular bulbs again.
Edited by Daryl Z71
Had an issue with our International DT466E not starting on Friday. Replaced batteries because they were bad anyways, but still no start. It was below freezing Friday and the block heater is bad in the truck so I waited till today. Fired right on up. Gotta run to the International dealer tomorrow and pick up a replacement block heater, I'll have my buddy install it. Crazy how it wouldn't fire, truck threw a code and I guess it shut itself down. Hopefully it'll fire up tomorrow morning, it's gotta be on the road
Sent from my SM-N920V using Tapatalk
    daveishi
    daveishi
  • Who's Online   2 Members, 0 Anonymous, 1,232 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
