Denso plugs original?
2000 Silverado, 1500, 5.3, 100k. Just bought from original owner. Everything was well maintained. Pulled plug see if they had been changed and found Denso PTJ16R15 plugs gapped at .60. Are these original? Is this even the right application for this plug? Googled, doesn't seem to be. Also had Packard plug wires, stamped on the coil pack end with Delphi 113. Plugs look clean buy not newer. Help appreciated.
AC Delco or NGK would OEM. The reason why that Denso # doesn't show for your truck is that GM has changed the plug gap to .040 now. Replacement plug is AC Delco # 41-110
Thanks. Read somewhere to check the numbers on the coil packs to make sure you have the right plugs.. Can't find any numbers on packs and this seems to be the plug recommended everywhere. Do I need to confirm this or is that definitely the right plug. Any comments on the wires. Thinking of just using the ac delco not trying to find this Packard set. Thanks again.
41-110 is the plug. .040 gap
The only thing I've ever seen needing the coil numbers is for the wire sets. One set is about 1/2" longer than the other
Denso is used by GM so they could be original. I havde seen Denso plugs inside of ACDELCO boxes. Packard and Delphi are GM spin off companies from years gone by.
General Motors - United Motors Service
United Motors was originally independent of General Motors, selling to all manufacturers until 1918, when the company was acquired by General Motors for $45 million (three quarters debentures and one quarter common shares) and integrated into GM on December 31, 1918.
United Motors became United Motors Service and continued to operate essentially as it had before. However, all of its production was now devoted to GM's brands. Alfred P. Sloan continued as the division manager, which carried with it a GM vice-president title and a position on the GM board. In 1923 he became President of General Motors and was Chairman when he retired in 1956. Charles Kettering, co-founder of Delco, was head of research at General Motors for 27 years. Herbert C. Harrison was President of Harrison Radiator until his death in 1927. William C. Durant lost control of GM for the final time in 1920.
United Motors Service would become a fully integrated division of General Motors in 1944.
United Delco
In 1971, the divisions name was changed to United Delco. With the Delco name becoming more well-known with consumers, the Delco name was incorporated into all of the divisions branches (Delco Remy, Delco Harrison, Delco Packard (Packard Electric), Delco Moraine).
AC Spark Plug Division
In 1899 Albert Champion, a champion bicyclist, formed the Champion Ignition Co. By 1905, Albert Champion had lost control of his company and in 1908 he partnered with William C. Durant of the Buick Motor Co. to form the AC Spark Plug Division of General Motors.
AC-Delco
In 1974, in an effort to streamline its operations and marketing, General Motors merged the AC Spark Plug with United Delco, which for years had been selling to the same customers, to create the new AC-Delco.
ACDelco
By the mid 1990's there were further changes to the division. In 1994, Delco-Remy, part of the division since 1916, was spun off to private investors and is now known as Remy International, Inc. Also in 1994, GM created Automotive Components Group to run Delco Electronics. ACG was later renamed Delphi and spun off from GM in 1999. 1995 saw a rebranding of AC-Delco. The hyphen was dropped and ACDelco received a new logo and marketing initiative.
Can't seem to find numbers on coil pack that make sense. 9603 stamped on side. Only numbers I can find and that sequence is way short of the numbers listed for the potential wires. Where exactly are the numbers stamped? Thanks.
United Delco
AC-Delco
ACDelco
Wow!
when gm first went to iridium plugs... they were made by ngk.. when i bought my 01 silverado 6yrs ago.. when i pulled out original plugs.. they were labeled ac-delco by ngk.. getting ready to put new wires and 41-110 plugs in again.. just hit 152,000 miles!! and still running like new..
That seems right. The only numbers on coil pack are 4 digit stamped. So if I match length that should be right? Looks like all other specs are the same. Even the stealership wasnt sure. Couldnt figure it out by vin...
My 02 came from the factory with those same Denso plugs as well...been running NGK TR5 standard plugs in it for years. I just change them more often now.
  • 3 weeks later...
    • No, not yet. Hoping I'll have something a little more definitive in the next day or 2. They seemed to be very confident they can order it. I do have some understanding of the whole allocations and restraints stuff so we'll see.   I think this is what I'm looking for.   3000 ORDER ACCEPTED BY PRODUCTION CONTROL
    • Then you haven't read your book. It also says check every 400 miles.   If you need to add multiple quarts in that distance then reading the stick isn't the issue. Put the two together and it will make sense. Read it all.
    • Following up on my topic, I put an O2 sensor in it which seems to have got rid of all the b2s1 codes (I ended up having multiple codes). Next I’ll try to figure out the P0011 but I might focus on exhaust manifolds first, they’re getting pretty rusty. I’m hoping this thread will help someone in the future.
    • I’m going off the instructions.
    • My expectations are a bit higher.    No faded paint or dry rotted plastic/rubber. I use a dressing and a ceramic sealant. No hazy headlights.  No door dings. Small dent in the front bumper. All rock chips repaired. No brush scratches. No windshield chips. No fender benders. Limit damage due to a proactive plan the included ceramics and PPF and prompt attention to any exterior issue. NO RUST. Stays out of the salt and had the rear wheel wells Line-X coated as well as the bed which has a bed rubber and has been under cover since before I bought it. Washed and detailed regularly. Rex chewed up the tow button, got whacked and the button replaced the same week. He's leaned his lesson. If I can train a dog the kids are easier.    All suspension is original save the King Shocks I installed very early on. 50 years ago dad told me a good shock will keep the screws in the dash tight and the front end mint. He was right. Everything within new spec yet, tight and aligned well several times. Coolant system is OEM save the modifications I made early on. Not a single leak anywhere on this machine. (Did repair an intake leak on #4 during the HPFP replacement.) The injectors I replaced didn't need to be. They checked out great. One of those, while I'm in there with the manifold off and the fuel rail apart things.  Not a stain or abrasion one to the upholstery. Have kept is covered since new. Never had a carpet, it's a work truck but the carpet squared I laid on the floor have keep the factory rubber liner MINT. Ceramic wind tint helps preserve the interior.    Original BRAKES with 60%+ left of the pads and rotors mic excellent. We just did a full preventative brake service. Disassembly, clean inspect including measurements, lube, Dot 4 power flush including ABS system.    OEM battery. OEM vacuum pump. In fact the only things not OEM are a pinion seal the high side pump and injectors and a small plastic shield around the starter. All hoses/belts etc.. are still in service and doing well. Original tires lasted 125K and had I known some additional details would have made it to 150K with legal tread. (Date out is six years, not 5 and Continental says they are good for 10 so I pulled the trigger to early)   I never let my children or grandchildren run the show. Feet on the floor and hands in your lap. Dog gets a pass.    A truck is a machine the gives you back whatever your willing to put into it. Same as a computer or a butter knife. I use a shovel but I scrap it, hose it off and oil it when I'm done with it. My original spade I've had 60 years.      Set the bar higher...you spend less money. No, before you ask, I have spent a fraction of the cost of a new truck in my entire maintenance program including disposables, filters/fluids etc.
