Help on getting a new HU
I'm having trouble hooking mine up. There is more wires than my single din. Everything that can be matched is matched.
Sent from my DROID X2 using Xparent Red Tapatalk 2
  • Replies 30
That sucks man!
I dread the installation, is it difficult?
Time to surrender the man card. Monday it goes to an installer.
It was blown radio fuse. But my remote wire for the amp I seem ed have pulled it so I gotta figure it out
Here's my 4400
Here's my 4400
Thats awesome man!
I shoulda got the 4400....couldn't afford it at the moment.
It was 395 on Amazon. Now evetthing wiring wise is done. I can't get the unit to go all the way in
A fuse was blown. I got a new one. But I'm having a shop install tomorrow.
Its in
A small piece of plastic prevented fitment for me. It had to be cut out. Its small piece that holds the back of the stock radio on the gmt-800. I don't know what truck you have. Install is simple if you have a set of dykes, and strippers, and you know how to splice. Plug the chime box into the OEM harness, and splice the radio harness to the chime box harness. Each wire is color coded. I had a couple non applicable wires. I also did the relay so my parking.g brake doesn't have to be on for the video. Spliced that into my remote wire for the amp. I have the buttons set to what I call "disco mode" they constantly change color. Red, yellow, blue, green, like a Christmas tree on PCP. When I changed from my old pioneer DEH-7300BT to the AVH-P4400BH the sound got clearer. I love the 8 band equalizer. Better than the high Med low of the old one.
I have been thinking about getting a new head unit installed in my truck. Do people prefer the double din dvd players like this as opposed to a regular cd player? I would like to install something double din.
Good choice. I've had good luck with pioneer. Great product.
I'm now running JVC arsenal adv793. Bought used but brand new, still in box so far I like it. Only problem I've had is a little chunk of plastic in between buttons on the front rattled out from my woofer shakin the dash do bad LOL. This is the 2nd JVC I've had. I also had an eclipse DD HU, got stolen...that thing was awesome.
I love this pioneer. Sound quality is better, call quality is amazing. When I'm on the phone it shows call time, phone Connection "bars" and battery life. I can customize all the colors of the screen and buttons. And album art is show with ipod
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
