2012 3500HD Shaking at Highway Speeds
I'm about to go in for my fourth time @18k. We will see. Good luck with yours.
  • Replies 111
Hey guys same issue here! My new 2500hd bought with 1 mile on the truck has spent 13 out of the 15 days I've owned it in the shop. Wheels and tire have been replaced by GM the vibration is worse now then prior to the fix. Now it might be a new drive shaft. I'm giving the dealer till The middle of the week to have this issue reaolved before I demand a new truck. Any suggestions??
I am happy to see that you have contacted Customer Service regarding this issue, also that your dealer is working with you.
Please keep us posted.
If you have any additional questions, please feel free to contact me privately.
Louis (assisting Tricia)
GM Customer Service
Hopefully this problem is fixed, the dealer seems to feel that it is. I will determine if it is or not. Louis can a dealer just swap out the truck or does GM have to buy the truck back? Sometimes I feel as if I'm getting the run around, possibly because this isnt being fixed as quickly as I would like it to be.
I think your running is just about to start,I have had my truck for 17 months and bitched about the road noise the first week I had it and GM say's there working on it. Ford's are looking so good right now.
Update- GM customer service has set up "another" case # for me. I was told a district specialist would be in touch to resolve my issue. I did get a call from the district specialist today assigned to my case. I believe the call came from "overseas" as the specialist spoke with a very thick accent and sounded to be reading from a cue card. I was not impressed. Anyway, I explained that with 4 previous service events at 3 different dealers to diagnose and repair the shaking issue with no resolve; I was not going to bring it in to another dealer unless a solution. It is a waste of mine and the dealers time to just keep balancing my wheels, thinking that the shaking is going to simply disappear. There are just too many documented cases of this with the 11+ HD HD trucks to just be a wheel issue. I believe it is a driveline issue.
I read an article yesterday about the 13 GM HD models. The article said that one of the changes was to the rear springs and axle to lessen wheel hop and provide a more comfortable ride at highway speeds. Hmmmm, do you think the engineers figured this thing out and are implementing it with the 2013 models, but calling it a tire balancing problem on the 11 + 12's?
At any case, I am not giving in even if we are talking replacement truck.
I will keep posting as it unfolds.
Stay safe
Steve
For those of you with this problem:
http://www.duramaxforum.com/forum/2011-lml-duramax-powertrain/110727-vibrations-over-70-mph-41.html
About 50 pages of this problem documented. There is a post in the thread of a class action lawsuit and an attorney representing truck owners with this "known" issue. I'm not too far off from calling this guy.
Here is the attorney I have on my truck atm. He works in many states. Im also talking with a couple different attorneys at this time for a class action against GM. They are clearly covering/masking this issue. We have all been givin case numbers and they have admitted to knowing there is a know issue.
Here is the attorney contact information.
LAW OFFICES OF STEVEN VEINGER P.A.
20801 Biscayne Blvd. Suite 304
Aventura, FL 33180
1-877-575-3666 Telephone
1-877-575-9666 Fax
Florida Lemon Law
Lemon Law these trucks...
Did not read the whole thread, and took a quick look at the link above to another site, and it brought back memories of 78 and up Chrysler products. Back then I was the transmission guy at a Plymouth/Chrysler dealership. Chrysler introduced the lock-up torque converter in 78. The first year of so had very bad vibration just after the converter locked up. The vibration was so bad the dash would vibrate up and down about an inch or two. You could not push the dash that far by hand, but, the vibration would move it that far. Ended up changing a spring and the end plate for the lockup valve in the valve body to fix it. That worked in most, some still required a washer behind the spring to delay the application even more. Reason I bring this up is that maybe this is something that is happening with the HD trucks. Is there anyway to stop the converter from locking up on the allison transmission? Do the trucks still vibrate if you manually shift the truck into a lower gear while it is vibrating? Again, I did not read the entire thread, this just brought back memories that may be applicable here.
I don't think this is a transmission issue, as the shaking problem exists with both gassers and Duramax. The diesels have the Alison and the gassers don't.
I think was just riding home today and the shaking was real bad.
One thing I can say is that some days it is worse than others. I can ride on the same road, same lane, same speed, same outside temp, same load, etc and one day it will barely shake then the next day it shakes like crazy. I don't get it.
For those that are considering the lemon law, it works and doesn't cost a dime. As long as you have the same issue 3x and it goes in for it and is documented. You can search my user name for my particular issue and/or send me an IM if you need any info. I had no luck with GM customer service, they kept offering me free oil changes, LOL.
Stay safe
Steve
Steve,
Can you share the source of this article? I'd like to document and present to GM Engineers, Customer Service and or my dealership. Thanks!
"For 2013, the Chevrolet Silverado 3500 HD Truck is carried over from 2012 with some new available paint choices and a slightly increased maximum GVWR of 13,025 lb. on some models."
So where in that article do they say anything about any changes that will resolve the issue being talked about here? This is the ONLY snippet that I find about ANY changes for 2013.
Sense the chassis set redesign of the HD's in 2011, they all use asymmetrical rear leaf springs.
My son found the article and I misread it. I believe the rear suspension changes were referring to 11+ HD trucks. Sorry about that
Steve
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 535 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
