I have the Mod 3, large charging handle. It is essential to me because of the scope, the regular charging handles last forever too.. But I needed the bigger latch for charging during hunting with gloves. Works amazing, Rainier arms also has a very nice dual latch charging handle but its a little more expensive. http://www.rainierarms.com/?page=shop/detail&product_id=3172
How do you like the BCM charging handle compared to the regular one? Can't tellby the picture is it mod 1,2,or 3?
Should last forever, they are much begter quality than any that are factory installed.
Sent from my iPhone4S
using Tapatalk
I would like to get them for my AR's BUT was worried about them being a snag point....Guess I will get one for one of my non-duty AR's and see how it goes.
I can try and get ya a side by side pic this weekend if you like. I s have the OE charging handle kicking around I think.
That would be great...A side by side would really help before I order a few of them. I am worried that it may snag on the front of my clothing/vest when hanging.
No issues for me with snagging, Just my input. All rounded edges with only serrations for grip on the front side, and they don't start for a bit so they stay off from snagging Molle gear ect.
Will do. I'm supposed to fly home Thursday. Been a long three weeks without my truck, my guns or bacon. :lol:
I have the large latch and I would NOT recommend it. Get the medium or small. Both are plenty big to operate with gloves. My large latch catches on my sling and one time even was enough to pull my rifle out of battery. Unacceptable. I've been meaning to replace it, but I have other things on the list before it.
I'm very satisfied with mine. That and the BAD Lever are two inexpensive but great modifications. Sent from my iPhone using Tapatalk
I dislike the BAD lever. It's extremely easy to lock back without one. The BAD lever has you put your finger near your trigger for non-shooting. Bad muscle memory. Plus they can get caught on stuff. You rarely need to activate the slide lock unless you have a malfunction. But then it's just as fast to chop your grip to the magwell to work the lever and use your strong side hand to rack the bolt. And then you don't need some extra junk sticking through your trigger guard. I would be interested in finding a bolt catch with a bigger paddle though.
Not worried about having to be near the trigger to use the BAD Lever. I know what I'm doing with the gun and its not like I'll ever use it for more than target shooting.
BCM charging handle vs standard:
Thanks for posting........Looks like I am going to stay with the factory charging handle on my duty rifle. The lever, even the small one looks like it may cause some snag issues on duty gear.
Check out the Phase 5 battle latch. It gives you a bigger latch without sticking out very far. Plus it's Ambi. Phase 5 makes some good shit and I would assume it's solid and good to go. My next AR will have it.
Edited by sputnik360
Here are some Pic's of a BCM Mod 3 and a standard charging handle.. and Sputnik that charging handle looks awesome.. but is even more aggressive then a bcm.
I apologize for so many pics, but the aggressive ass one above is bound to catch more, it should be noted if its cold out i'm shooting in a Carhartt jacket. These should give a good comparison all the way around, top down, from behind and of the charging handle itself.
Some side by side action above, forgot to quote you so it pops up in your email
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 2,122 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
