What would YOU do?
Just need some thoughts. I have a 9500 Ramsey winch that came off my old truck, it works great it's just been sitting in the garage taking up space since I bought my 06. So would y'all put a winch on your current ruck if you already had one available? All I need is to buy a mount and bolt it on and I'm done. It's the nice one too, with the wireless remote. Any thoughts?
Well if you go off-roadin' alot and need it to help pull you out or maybe even some work related stuff you could use it for then I say go ahead and install it.
i have seen GMT800's with the winch mounted behind the air dam(the plastic thing with the foglights) and thats what id figure out how to do if had a winch. i know that Warn actually makes an airdam thats have a hole for the winch and it looks pretty cool.
i think winches are a little bit bulky unless you have giant steel bumpers with a place to mount it
You could mount it in your garage and use it for lifting. :)
or mount it in the bed to help load stuff
Sent from my ADR6400L using Tapatalk 2
Yea that's the other thing, I can't find a mount that really makes me say " wow I want that on my truck!" the price is rough too. I bought the warn trans4mer setup for my 98 for $500 bucks out the door. Grill guard, brush guards and winch tray. Just the grill guard and winch tray for my current truck is over $700. Plus there's the issue of hanging 200+ pounds off the front of my truck. It's not that great for the handling lol. I mounted it on a receiver cradle when I took it off and just never used it, maybe I'll just keep it on that and use it or sell it. And put that $700 towards some new rims. I don't remember the last time I went off road so j guess Its not like a major necessity or anything.
If you have a use for it then yeah put it on, but if you dont and mount it just for looks I say no just sell it and use the money for something else. A winch thats on a truck and not used will go bad over time so your better off selling it.
Yea that's a good point. Not much point in putting it on for looks when someone else would actually use it. I've seen the behind the air dam setup too, but mine has the integrated solenoids above the drum Which would make it a very tight fit. I'm not positive I wanna sell it yet. It's got sentimental value in a way. It was a high school graduation present from my patrents lol
  • 3 weeks later...
Ok so can someone give me an idea of a fair price on this winch? It was bought new in 2005, and mounted on my 98 k1500. Its a Ramsey patriot 9500 with integrated solenoids across the top. It has the wired and wireless remote systems that came with it and they both work. It's now mounted on a receiver cradle with quick connects and I also have the wires to go on the truck. It has always been covered until the cover started to tear, but it's been in the garage so it basically looks like new except for a couple rock chips. It's been used less that a dozen times and is fully functional. I was thinking $800 with all the multi mount stuff and maybe $700 without. It also has 105 feet of cable and the roller fair lead, jus like out of the box. Does this sound fair? Thanks in advance.
that might be a little pricey. but it all really depends on where you live. put it on craigslist for the prices you want and go from there. people will offer you below that anyway.
Yea I emailed a guy on Craigslist last night, he said he was looking for a warn or Ramsey winch, 8k or larger. When I told him my price, he politely refused and said he could by a new warn m8000 for 550. That's true, but it's like comparing a scooter to a Harley IMO. This winch would run close to $1200 if bought new. I'm not tooting my own horn here but it's in like new condition. I don't have to sell it and I definitely don't wanna low ball myself. Thanks for your advice though, that's what I wanted to hear. Just wanted to see if I was in the ballpark or not.
I've also noticed that I don't see very many winch equipped trucks in my area, and I see almost none listed on Craigslist. I guess I'm just not in a good area. Oh well lol
If I didn't have a use for it I would sell it and try to get some money back out of it.....No use holding onto it if you don't plan on putting it on the truck.
:withstupid:
    • Pryme ! I was thinking of adding one to my 2024 6.6 gas  . Could you elaborate a bit more on your statement  Thank You
    • What a wonderful result! Great story telling to. You are quite multifaceted sir.  I'd keep it. Four is my limit too and yet we have five as well. One assigned the 'salt car' to do all those tasks you hate to ask of your 'Save for Good" crowd. 😉    Don't forget the antifreeze.    The Iron 4.3 is a favorite of mine.
    • Thanks Buck Wallace ! The more owners that tell me they are getting the same noise the more comfortable I will be with it !
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
