Is upgrading to navigation worth it?
I've got a 2011 Sierra SLT without navigation and I'm thinking of putting it in. It's fairly expensive and I was wanting to see if it's even worth it! Pros and cons would be nice
I'm upgrading because I hate extra crap in my vehicle. I don't like extra wires/cords. The only thing on my dash is my radar detector and that cord bothers me sometimes.
We have the factory nav in the wife's Tahoe and its very convenient. I would love to have it in my truck but I don't need it and as you said, it's expensive.
I have it in my truck and like it a lot. However, it came with the truck.....given the cost of the unit, I wouldn't personally put one in afterwards. A good TomTom or Garmin will do just as good and a lot cheaper.
Why not look at the advent ogm1? Works very well, integrates with stock features without having to buy extra modules.
I find my Garmin handheld much more useful than an aftermarket in dash navigation unit.
1. I only need it when I go on long trips where I am not familiar
2. Daily Driving back and forth to work I have no need for an in-dash nav unit
3. It cost me $159 bucks.
Just my personal opinion, but I would much rather spend the 1000-2000 dollars on something else that I would use much more often.
Its built into my phone and that's all I need. My phone also gives me current traffic conditions
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
Would that be in your "PIECE OF CRAP DROID X2"?
This topic is more in line with what you "want" as opposed to what you "need". Realistically all anyone really needs is a fold up conventional map. My phone does all that crap as well, but, I want to have the head unit in my truck to plot the course, tell me when and where to turn, and to correct my course when I stray off line to stop at strip club. And to be clear, I "want" to go to the strip club, I don't "need" to.
I personally don't like the nav. Rather have the Garmin Nuvi that I have. As stated above, $150 and lifetime map updates, can't go wrong there.
My brother in law has the factory nav in his tahoe. I think my mid-to-uppper grade garmin nuvi is superior. My garmin nuvi was cheaper than the factory option too and I have lifetime map upgrades.
I have the factory Navigation in my 09 CTS and in 2012 Denali. I will never buy another vehicle without it. It has come in handy several times and saved me a lot of driving around finding where I wanted to go. Some people spend $2,500 on big tires, wheels, loud exhaust, tunes etc. I have had the Garmins and a Magellan Roadmate. All well and good but driving and looking at something the size of a playing card does not work for me.
I am a Garmin Nuvi owner / user. I travel a lot for work so it gets used a lot in the US and some outside the US.
That being said, I would really like to have a OGM1, I just cant justify the $1k to spend on it. And I have personally never been a fan of the 2500$ factory nav option. Price and less features than aftermarket kill it for me!
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 518 Guests (See full list)
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
