2008 5.3 v8 oil burning, plug cylinder #6 fouling repeatedly ....help
stevemaman
I am new to this forum. In advance ,I thanks all of you for all the information I already collected .it has helped me pinpoint my issues..
So,here we go :
2008 truck , 4x4'built in USA,engine manufactured in 2008 February,truck finished in February and shipped to africa where I ordered the truck through a gm dealer.
It has 50k approx. it has been great till recently.
Took it to the gm dealer after it started misfiring and the code showed up as check engine and stabilitrak.
The put a scanner and clearly showed cyl #6 misfire.
We took all plugs out with the gm tech . All plugs perfect but #6. It was fouled because of oil.
We put new plugs in it...erased the codes..started the engine..ran great for 2 min.. Then again,scanner showed cyl 6 misfire.
Took it out and oil it is !
The tech was quick to say u need a new engine ....after sone arm twisting,we got to ..you need pistons and rings ....then I read all the forum info on oil burning and lugs fouling and called them back last week. I am in Canada and keep the truck there.
So here are my research and questions ... I am getting killed there with techies that never and don't know zip about the common issues of 5.3 of oil and plug fouling , and valve covers with baffles, and flex fuel regulators for spraying oil to the cylinders that go bad, and all the different tbs ... They are lost and ignorant. I am forced to do all the work for them of else I am lost with the truck there. I need to pinpoint as best as I can and take the parts with me next week.
I never did an oil consumption test but it seems not to be an issue at all..no smell, no smoking..and the is fire issue is a first for the truck. Been great so far.
- are my rings shot on cyl 6 ?
-are my rings sticking and need the cleaning for rings gm recommends ? If yes, then why did just that one cylinder stick and all others remain perfect ? Wouldn't make sense..
-valve cover with baffle....PVC valve,... I understand 08 had the new style valve covers ? And even if mine had the old style, wouldn't I find oil on more than one plug that would misfire or at least show sins of oil. ...?
-can it be from the valve or valve guide or seal ?
-can it be frm the flex fuel where apparently,08 motors we made with a different oil spraying system for each cylinder ..and in my case,#6 sprayer is not regulated properly or defaulting therefore shooting too much oil ? In that case, I could just have the cleaner tbs for the rings gm recommended, then fix the regulator issue of the flex fuel ..
Please , consider my motor was build in feb 08, any ideas would be greatly appreciated. I travel next week. Mechanic wants me to bring be piston,one ring set,crank bearings,and all gaskets.... I am not convinced I need new rings , I feel Otis either coming from the fuel flex system or maybe the valve cover. (but then again, why just cyl 6 if the valve cover would be at error,then a few cyl would see oil..not just cyl 6) ...
So am I right to feel all is pointing to the flex fuel system sprayer of cyl 6 !?
How do we check this ? What's the way to see if defective or they say we need to reroute it with a shield.. .???
Thanks in advance .
What do you mean the Flex Fuel System???
Does cylinder 6 deactivate when AFM kicks in?
I bet all you need to do is replace the valve cover gasket and spark plug hole seals. Oil can be getting in there is there is a bad seal. That may explain only a problem with one cylinder and will definately cause a misfire.
Isn't this still under warranty? Does Africa get the 5 year 100,000 warranty? Don't understand the flex fuel oil spraying idea either. There is no connection between flex fuel (ability to use either gas or e85 fuel) and any oil spraying. You may be referring to active fuel management, where cylinders are deactivating to conserve fuel. Go for warranty first, no sense trying to fix something that is going to be free. Not sure I would ever re-ring one cylinder.
The PCV valve vacuum hose goes into the intake directly above the #6 runner. If you are sucking oil through the PCV system it will foul plug #6. I would seriously look at the PCV system before you tear the whole engine apart.
I got mixed up with the flex fuel and the active fuel .sorry..... The active fuel has a bulletin requiring a shield, the valve covers have a bulletin requiring a newly designed baffled cover .... My real question is why just cyl 6 spark plugs gets fouled by oil ? And after we change the plug, 2 minutes later, same thing, fouls again ....
the truck had a 3 year warranty ! For Africa only. Since it was delivered through a dealer there..sucks ! Your post is very interesting... Cyl 6 is right below the PVC ...so if i do not have the revised valve cover and PVC system with the shield and baffle, hen the cylinder that will get hit he most is my #6 ! After reading a million posts,you are the first to mention this. I tried looking at others who had a cyl 6 plug fouled but could not locate.. What I plan to do is : have the dealer remove plug cyl 6. Clean cylinder . Disconnect PVC system and redirect to a hose to a bottle .... Instal new plug on cyl 6 . Erase all codes. Start it. And see if 2 minutes later,like the
Last time, it fouls again immediately in front of us ! Does this make sense what I am saying ??
Understand that where the truck is now,these guys only work on euro gm cars...this is one of very few gm trucks there....
