Do you think GM will make a similar cab to dodges megacab
Im very curious im there will be a sierra or silverado with a cab close to the size of the mega cab..If you guys havent seen one in person..It is pretty awesome!! Im sure the guys here with kids and dogs know what i mean, My girls are getting bigger and the dogs go camping with us also, so with two kids and two dogs 'one of them a 145lb mastiff ' In the back of an ext cab..It doesnt work well, The crew cabs arent really thatmuch bigger or anythingwort being excited about.. So im kinds stuck going with a mega cab cummins, IF..there was a mega cab sierra i would buy it over the dodge! Im sure theres alot of guys that ould agree,, The extra space is really nice.. How can we, GM consumers give input..so they hear us and will consider a new cab configuration.
If you need a truck to haul inside the cab they may be great, but if you need to put anything in the bed you are out of luck, I think the bed on the mega cab is 5' 6" or maybe 8". A friend of mine has one and everytime he needs to haul something he needs to get his brothers truck with the 8' bed. :jester:
My friend has a mega cab and it is way better than any crew cab for rear passengers. And as for the short box comment I got 2 words, tailgate and straps.
Yeah, the extra room in the megacab is only behind the seats for storage and so they can recline. I didn't find it any more comfortable than mine to sit in.
And the truck itself looks ridiculously long- almost needs a lift just to sit right.
Yet still I like them!
I know I can sit in the back seat of my uncles Mega cab in a comfortable position. The seat design doesn't offer much comfort to me. But I have a bad back
Sent from my DROID RAZR using Xparent Red Tapatalk 2
I saw a mega cab with a 5th wheel attached to it.. I talked with the guy and he said he never had any issues.... His hitch also slid along the rails..
As far as the bed, Pretty sure its 6' 4 or 5", The total length of the truck is 5" longer then my ext cab long bed.. the wheel base is 1" different, There 160" im like 159"
It grows on you... I didnt lie it in the begginging either!! But when you see the cab in person, And how much it will make life easier, It does grow on ya..
I really meant to ask you tour feeling n ur acceleration..Your 0-60 and/or 1/4 mile..Does i feel like a basic V8 camaro or mustang...Or are you feeling more like a vette or viper??
Me?
I would love to have the mega cab with a long bed.. If the money was available at the time I WILL get the long bed conversion!!
Yeah I almost bought one myself, for sure a nice truck! And with the cummins its the lesser evil of the big 3 diesels- a bit less power and MPG's but no piss tank, still get a standard trans and still the best puller. From what I read over on DodgeTalk you can unplug the EGR and delete the DPF without a tune and really wake them up and improve mileage.
The 07-10 or 2011 make 350 hp and 650 ft lbs.. the 2012 6.7 makes 350 or 400 hp and 800 ft lbs!!
I wonder what the changed or did different to pick up that xtra 150 ft lbs of torque??
I measured beds between my uncle's Mega Cab and my 2004 "short bed" now the std bed. Mine is 1 inch longer. we had a pissing match. we both wanted to lose. I had the longer bed so I got the bed load
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
