clunking noise
Hello, I have a 2007 Silverado and am experiencing two problems with it. Problem 1 there is a noise coming from the rear of the truck, either from the leaf spring of rear end, couldn't really tell. Problem 2 is intermittent. When I start the truck sometimes it will rev up to bout 1k to 1500 then shuts off and service air bag light turns on. It does will do this a time or two then starts. Today it took 3 times before it would fire. The thing today, my girlfriend had drove it to pick me up and shut it off. It had maybe been off for 5 minutes when it did this. Thanks, sorry for the long post.
Does the clunk happen at a light? Might be the slip yoke. Common with gm trucks sounds like a bark and feels like someone bumped into you.
Really hard to diagnose without being there could be a lot of things I would start with u joints and have a friend walk beside you while you drive to see if you can pin point it.
Good luck others will chime in this forum is great!
I havnt had it scannes yet, since the light never stays on and tried walking next to it today, but could tell. I did see that the was a tsb on something similar.
Took it to Autozone and they said they couldn't scan it since the CEL wasn't on. I pulled the neg, see if that clears the codes and maybe fixes the problem. Still working on the noise. Thanks
That's crap, I've had mine checked without lights being on. If they have a good scanner then they can scan regardless. Hope you can get truck fixed quickly, I can understand the frustration.
Thats what I was thinking. I think I may have the noise half way diagnosed. I think its a wheel bearing going out. Going to check it this weekend on the lift.
autozones scanner does not have the ability to read airbag codes, you will have to take it to a shop to have it read.
  • 5 months later...
Any news on the clunking? I am hearing some clunking noise on my 03 Yukon XL, but it is so random and intermittedly that I can't recreate it when I want to and hard to diagnose. It is when driving (not stopping or starting), and does not occur on every trip, but about every 3 or 4th drive.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
