How was your day?
yukon25008.1
Wuss. :rollin:
P.S: I gave up cause I realized I probably couldn't keep up with the 75hp gain you have from those tow mirrors. Oh and the LQ9 :drool:
If you had stacks I wouldn't have even tried...
hey dont hate on his mirrors
  • Replies 396
Lol I wasn't hating on them. I think they look good. He was teasing me about my reasonably sized power folding mirrors, so I had to throw it back. :lol:
My housing alliance for school here is more than there and I have a good job here. Not worth it. If I can hot my power goals while passing emissions then that's an achievement
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
buy a house dont rent.
i dont like how even on the GMT900's the tow mirrors are not power fold.. the tow mirrors actually need power fold not the little ones
Chris isn't older than me were both 23 lol and it wouldn't work because his truck can't go offroad :lol:
Sent from your truck via Tapatalk
Oh it can sarah. Its done it in the past. The last time I had major fun off road in this truck I left the woods with $7400 in body damage. I still have the 16's with 265/75R16 A/T's on them.
And I am older. You were born in 1990. Children of the 90's think they know so much. I was born in 1989. I am 8 months older so I win
I am renting for now. The market is hell over here right now. I was advised to not buy. That was by the real estate agents I work for. People are asking too much for their houses
Jeez, I feel old- I was born in 1984. :lol:
Speak for yourself I am a child of the 70's :lol: 1979
No wonder why I bought a camaro already, damn mid life crisis.
Me too, the other day I was reminding some friends we will be 30 in 2 years. Amazingly I have retained a lot of friends from high school.
Sent from my Nokia 5190 using Tapatalk 2
To make the day better I just cancelled the $500 hotel room on the beach I was supposed to take the now ex-girlfriend to this weekend
Good lord! A mid-life crisis already...... This worries me.
Can I go?
Reservation has already been cancelled
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,326 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
