Super chips flashpaq 2865
db3812
Please adjust your sig pic size according to the Site Rules.
9. Signatures may contain images, but may not be any larger than 700x200. If your signature is larger than the allotted size given, you will be requested by a moderator to resize your image. Please also keep text signatures under 5 lines. Failing to append with a moderator will result in the removal of your signature.
Happened to me too db. I changed pics and it had to get smaller. As for your flashpaq, I used one on my '07 Vmax, and it really woke it up. I know it's not a custom tune, but if anyone can't afford custom, the mileage, 87 octane, 91+ octane and towing tunes are well worth what he's asking for this. Then throw in the tranny shift firmness and shift points, increased rev limiter, ability to remove speed limiter and the fact that you can adjust for tire size changes and undo all of it if you want to, you really can't go wrong for a multi-function hand held, especially at half price.
Ok. Changed pic size. This is still available!
Your sig pic is not showing.
