Oil life remaining indicator
You can buy Dexos-branded oil from the dealer I do believe. No idea who makes it. Just seen the bottles on the shelf in the parts dept. They might just be props though.
Yes, you can buy dexos branded oils wherever you want BUT GM is getting money no matter what company you buy it from (fee based on oil companies market share). It's their brand on the container and being intimidated or coerced into buying a GM branded product is totally against the Fair Trade Act (Magnuson-Moss). That is an infringement on free trade.
All you need is to have is oil you use meet their requirements, that's it, end of story. If they (the dealer) tell you differently, it could be construed as against the law and unethical of them to tell you that.
GM is "not recommending" any oils that won't pay them to have their brand on the container.
YES, dexos IS a brand, trademarked and licensed by GM. You cannot use it unless you pay them a fee.
brand [brænd]
n
1. (Business / Marketing) a particular product or a characteristic that serves to identify a particular product
2. (Business / Marketing) a trade name or trademark
Incorrect............Dexos 1 is NOT synthetic blend oil or even a brand of oil at all. It is a rating, don't confuse yourself. There are several oils that meet the dexos1 specs.
Sent from my iPhone4S
using Tapatalk
http://www.archivedsites.com/techlink/2010/11/dexos-engine-oil-availability.html
http://www.archivedsites.com/techlink/2010/09/the-new-gm-dexos-engine-oil-specification.html
and
http://www.gmdexos.com/licensedbrands/dexos1licensedbrands.html
Don't see any conventional oils on this list, nor have I seen any that meet the spec.
elcamino,
Seems a few are misunderstanding my post about Dexos being a "brand"......Modil1, Castrol, Valvoline, Quaker State are all brands of oil. The Dexos1 is a certification, NOT a company such as the ones mentioned. GM owns the trademark and you need to pay them money for that label (dexos) to be on any brand of oil.
There are several oils that do not appear on the GM Dexos list that do qualify but will not pay the unreasonable fee to gm to have it's dexos label on the bottle.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
