New Toyo Open Country A/T 2's
Love them, Quiet, Handle great, No real fuel mileage decrease, Look good... Great tire, couldn't be happier!
522134_10151889850479012_777537229_n.jpg68543_10151889853239012_927689859_n.jpg156029_10151851663954012_601823756_n.jpg
What size did you get? Mind saying where you got them from? These are on my short list of tires when I need to replace my Duelers..
Here's another pic from today
Just got P Rated, they are a 5 ply tire... 265/70/17's
Bought them online here in Canada
I have the Lt's on my truck. 285/75/18's i believe. I love em, tow a big trailer with them, and they work great!
  • 4 months later...
After much debating between the Cooper AT3 and the Toyo ATII, I finally went with the Toyo. Other than this thread, I couldn't find many pics of this new tire on a 1500 series truck with stock wheels, so I have included several pics that will (hopefully) help someone else decide which tires they want to go with!
Before (265/70/17 Toyo AT):
After (285/70/17 Toyo ATII)
Looks good its nice to hear they are good tires I have the 22 inch toyo at ll's I just wish I could get my wheels to fit to test them out.
I have them on several work trucks one set burned off in 30k. Others are chunking hard at only 10k. Mind you our trucks are F-350's with a heavy darkroom on the back.
Owner of the Company is running them on his denali hd in 275/65r20 and had one blow and delaminate at about 5k.
I am sure there are reasons for the accelerated wear on the tires but we seem to be having no luck at all with them
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
