'11 is going to need tires soon, suggestions?
bowserb
The Michelin LTX M/S is an awesome tire. By looking at the tread you would never think it was an excellent snow and ice and mild offroad tire. I know people that get 70k-90k miles out of them. The Cooper tires I have had in the past have also been good. I had a set of Bridgestone REVO's but after 6 years I took them off because they got hard on me... (35K miles and plenty of tread left)
  • Replies 52
One thing about the BFG All Terrains, they throw rocks really bad. So if you're doing lots of gravel, I'd get something else. I've put em on my last two trucks, because they are such great tires. But they just destroy paint jobs. They are also quite soft, you have to rotate them LOTS.
I have Cooper AT3's on mine. So far I like them, but only have 3K on them.
I ran across a link to discount codes for tirebuyer.com on bobistheoilguy and thought I'd share. No promises these codes will work, but worth a try for $100 or $50 off.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2997693#Post2997693
http://www.reddit.com/r/cars/comments/1e0nwo/buying_tires_soon_read_this/
True, I got mudflaps since my parents have a gravel driveway and all you hear for the first three miles is the tinking of rocks against the paint... Then of course theres the ones that hang on just long enough until you get on the highway...
It's unfortunate, because I found they were the best tires for all year round. Snow/Ice, Mud, and even highway, as they aren't that noisy. But if you do lots of highway, the tread just burns off em as they are so soft.
I think when my stock ones are done, I'll be buying to Yoko Geolandars A/T. Tried the Toyo At's, they suck in the winter, and in mud, but wear nice and are good on pavement, and don't throw boulders at your paint.
I'll have to agree with White on the Michelin LTX M/S2s; they've been great for me in all situations I've encountered.
Just put a set on my Siverado, and love them.
I try not to, that's why I got mudflaps! They protext the outside paint so now i just hear it underneath the truck (I have oversize tires so the inside of the wheels are still uncovered), and well that's normal wear and tear to me...
my toyos threw boulders when they were new
Sent from my Nokia 5190 using Tapatalk 2
Min too, my parents use mutated gravel, much bigger than the normal stuff, almost pebble/small rock size...
LTX MS2's cannot be beat if you drive alot of highway with occasional off highway operation. Treadlife is exceptional 50K plus if rotated, proper air psi is kept.
I've really liked my Cooper AT3's other than treadlife. I will be lucky to get 30K from them. It seems they wore decent until 15K and then wear accelerated.
I had the geolander ats on my last truck, great tires!
Have any of you guys ever tried the nitto nt420s? They are suppose to be good wet/street tires, good for everything except snow. Discount tire gave me price just under $700 for the set with certificates for free replacement, what a are your thoughts guys?
A lot of guys on SilveradoSS.com like them and they will be my next tire
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
