Upgrade to dual rear piston, and 05+ fronts?
Searched the web for those calipers you listed and after shipping they all come to around 650, and thats without the caliper mounting bracket!!! And thats on like 4 different sites
  • Replies 100
they came out to 645ish. but, I went onto the ACDelco website and found something out. Those rear calipers you listed are for an 05+ Silverado, not an SUV. The SUV rear caliper part numbers are as follows:
RR: 172-2394
LR: 172- 2393
Keep in mind these are the ACDelco numbers. Actually makes finding them a lot easier online. But not sure if there is a difference between the SUV two piston rears or the 05+ rear disc two piston calipers
I listed 03-05 silverado ss rear caliper part numbers. they had rear 2 piston
Oh ok I figured out what I did wrong. I clicked on 06 Suburban on ACDelco and it came up with a different part number, but 00-05 is the same part number that you listed for the rear. I'm kind of confused, because I thought 00-06 Burbs and Tahoes were built the same
The only change I know if in 06 for the burb I know of is the LTZ which was basically a Denali with Z71 body features and Silverado SS wheels
Alright the difference between 172-1611 and 172-2393 (which in gm part # is 18043520) is one is set up for active brake (172-2393, RPO code JL4) which I guess, as you said it, is probably part of the LTZ trim package, but not sure what it does
EDIT: It is for stabilitrak. Not sure how the caliper is set up differently (looks the same in the pics) from 05 to 06, but it is. So if your looking at doing this (for those of you reading this) look into 00-05 Burb rear calipers
If I went with NAPA semi loaded calipers (w/ brackets), EBC Sport Rotors (all the way around), and EBC Green Stuff Pads (all the way around) the total would come out to $853.69 after taxes and cores returned ($969.78 before core returns, but with tax)
If I went with all genuine ACDelco calipers (like Chris is going to do), and then the EBC rotors, green stuff pads, and cardone brackets, the total would come out to $1210.31 with no sales tax (all online ordering)
Not sure if I should just fork out the extra $350 for brand new ACDelco calipers or just stick with the NAPA remans. If NAPA doesn't accept my calipers as cores then the difference would be $240. Any advice y'all?
Oh, and happy birthday Chris!
I may go with remans, because my front rotors will be $645 alone
Yeah, I looked them up and figured you might as well upgrade to a Wilwood kit if your going to spend that much on just rotors. Actually, the Wilwood kits are not that bad compared to Brembo and the other B companies. Only 2k an axle, compared to 4k
I will be going to a Wilwood or Baer 6S but that is later on
I think brakes and possible regear is it for this truck. My next truck is going to be a diesel, preferably an LBZ Duramax. I know it aint much newer than my truck, but those are some of the best Duramax's they have made, so I have heard
My factory bracket bolts should be fine, correct? I don't need to get longer ones?
Also, if I did go new ACDelco, could I reuse my caliper bolts, or would I need to buy new ones?
We had EBCs on the TBSS and SSBC big bites on the SSS, both great rotors, no issues. Sent from a jelly bean.
Hey Jenna, the EBC rotors didn't tear your pads up, did they? I was reading around on a couple other sites and people were saying the rotors with the dimples (the sport rotor) messed up their pads pretty bad when they did a couple of hard stops, like the dimples cut into the pad?
Doesn't seem right to me, but who knows, there is a lot of pressure on those pads
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
