who makes a good add a leaf for gmt900?
i have an 07 1500 crew 4x4 new body and have the RC level kit. but sometimes when i tow the butt squats so i want to add an add a leaf. who makes a good one?
I ran a Super Spring kit for a while. It definitely helps and is easy and fast to adjust. Problem with it and the add a leaf is that it makes the ride harsh unloaded
Sent from my Galaxy Nexus using Tapatalk 2
These folks (http://www.generalspringkc.com/default.asp?p=product&id=1684&parent=549) sell true "add a leafs", both long and short. An added leaf will stiffen the ride, and probably raise the rear too. If you're towing the same trailer all the time and for long distances, and it's heavy enough to squat the truck, then a WD hitch system is the way to go. Other options (that I haven't used) include air bags and bumpers (timbrens). Neither distribute the load like a WD system, but should be fine if you're not overloading the rear axle.
zoneoffroad.com carries add a leafs, which is what im running. i didnt gain a lot of height maybe 1" but it definately helps when hauling a trailer, or a wheeler in the back. it still squats just not as bad. zone said it added about 800 lbs to the truck but not to over load the truck just because it just added 800 lbs.
my buddy added hellwig helpers and it stays stock as far as the ride, but when you put weight in the back is where it really shines
I know people who have used the Timbren system and they say the ride is really bad. Haven't riden in one myself. I have the air bags and the on board compressor. Really like it and the ability to wirelessly control the ride height while loaded, or unloaded. Not really stiffer with the bags mostly deflated.
I ran a Super Spring kit for a while. It definitely helps and is easy and fast to adjust. Problem with it and the add a leaf is that it makes the ride harsh unloaded Sent from my Galaxy Nexus using Tapatalk 2
Ive ran the Hellwig's for several years on different trucks. When your not running a heavy load you adjust it accordingly and it rides like stock.
2500HD rear leafs... Get them at a wrecking yard for $100. Cheap and effective
They should. Mine did. Go from a 06-08 2500. Those all carried the same frame
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
i know it is subjective but how much rougher is the ride with the add a leaf? i had one in my older gen 1 tundra, they were already installed when i bought it so i never had a chance to notice the difference. the truck never felt to have a harsh ride. and the current gmt900 is so soft i don't think it would be too bad.
how do you guys feel about it?
I went from 3 leafs to 5 and it is a little firmer but with poly bushings feels more controlled
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
