2006 Towing Mirrors Question
Looking at picking up a set of towing mirrors for my 2006. The truck currently has the power folding, signal, dimming mirrors. I notice on alot of adds they state that the mirrors will not work with these options. I realize the towing mirrors aren't power folding or auto dimming. Is it just that these options will not work with the new mirrors? Or are there issues controlling them?
Thanks
Those are the only issues. Signals, movement, and I believe heat will still work
Thanks. Was worried they would have different connectors or something. Didn't want to find that out after I drove to Montana to pick them up.
Are the Kool Vue's a reputable/quality product?
I have them. The lenses shake a little, but the music I listen to has a lot of bass and I drive about 80-85 on the highway, I am assuming you are looking at part numbers GM73EL-S and GM73ER-S so you still have signals.
Yeah those are the ones. Was thinking of going without the signals (never had them on other trucks) but I guess I'll stick with them again this time.
I like them, My truck didnt come with them and they work all plug and play
i have power heated mirrors on my 2011 sierra, any idea if i added tows with heat, power and signals if they would work?
They will. If you decide to do it check the link at the bottom of my post.
I can give 03-06 tow mirror advice, Mike knows the 2007-2013 trucks
Just get the ones with everything. They will work even if your factory mirrors didnt have the functions. I had a set of basic power mirrors and swapped them for loaded tow mirrors and everything worked.
As far as Kool Vue mirrors go, thats what I have and I like em. Cant tell them from factory.
Thanks for all the advice. Just ordered a set. $295 all in. Not bad considering what they want for them at the dealer.
All i know is that the mirror shakes like crazy going down the highway. Drives me out of my mid and i have the GM ones.
I had some luck gluing fishing weights to the back of them on my work Duramax. Didn't completely solve the issue but damped out the vibrations some.
my mirrors were from ebay and the right one shakes horribly and the other dosent shake at all... not bad for 160 for both though
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
