have a 12' Cruze and the rotors are warped with only 29k on it.. I drive it pretty hard.
Was trying to figure what rotor/pad combo would be the best, obviously im not going to go OEM since they cant handle my driving. I was thinking maybe slotted or grooved rotors? or is that over kill...?
or was thinking just EBC premium rotors and greenstuff pads.. never had an EBC product on anything but a dirtbike and i have heard only good about them.
It's not you trust me. My wife's have been junk since around the 12k mark. Were going to put EBC slotted and dimpled on hers with the EBC pads.
No issues with our 2011 but then we only have 7k miles on it. I would think EBC would have a beefed up rotor for it and have only heard good things about their pads.
hmm ok well thats good to know... mine have had a shake since like 25k. its not bad, its only under hard braking.
wheres the best place to get EBC brake? how much are the slotted rotors your getting?
Try summit racing.com
Ryan
  • 4 weeks later...
Changed the oil in the Wife's Cruze today. She has just over 43,000 miles on it, so I decided to look over the brakes to see how much pad was left. Pulled off the drums, and hell the pads look like they have hardly worn at all. Thought maybe the drums needed adjusted so I tightened them up a bit. Not sure if it will help anything or not.
i dont think my pads are worn.. just my rotors are shot. ill have to try and tighten them up some when i get a chance
from serv manual...
Drum Brake Adjusting Hardware
Provides automatic adjustment of brake shoes to brake drum friction surface
whenever brake apply occurs....
why are you adjusting the brakes again ?
from serv manual...
The auto adjustment is crap. When I was at the dealership it was common to adjust the drums.
Have to agree with that. I figured they auto adjust, but you wouldn't know it by looking at the pads. Looks like the pads are just in there for looks...
Yea I was kind of wondering if the Wife's went to crap so fast because it seems like the drum brakes are literally doing nothing. I know the rear brakes don't do a whole lot of braking to begin with, but these actually look like they aren't wearing at all. Hell my 09 truck was at the dealer one time with around 15,000 miles on it for an inspection, and they claimed the drum pads were half worn out where her car's aren't even half way yet at 43,000 miles.
Not sure if the adjustment will help anything, but I figured Id try. Didn't stop any different afterward. Oh well I'll just put the best rotors and pads I can buy on the front, and to hell with the drums lol!
    d.lowrey
    d.lowrey
  • Who's Online   0 Members, 0 Anonymous, 3,974 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
