Switching out grease zerks
Because of where it is I want to swap out the straight upper end of idler arm mount grease zerk with one that has a 90 degree bend.  Has anyone swapped this one out and was it difficult?   Do they sell spacers to make sure the zerk points down when I'm done.
:cheers:
Not difficult at all.  Just use a properly sized box end wrench, make sure you don't cross thread, and only put 10 ft. lbs or so of torque on it (these things are aluminium).
Also, check the check ball in the new fitting before you put it on.
6mm not to bad to change.  I did get pretty greasy
Yep, same here.  I think I remember someone saying you can get to the original (straight one) easily by turning the wheels.   :cheers:
I didn't think of trying that before I changed mine out though.  :(
Here's a pic.
With my 99 Tahoe, it didn't matter how I turned the wheels, I couldn't get to the zerks.  I changed to the 90's.  It was easy. :popcorn:
Yes,
I did change the same zerk on my 02 Tahoe about 3 weeks
ago. It was very easy. Use the box wrench and , if you have
it, a small mirror is very useful to see what you are doing. The
mirror is a nice to have only. You can do it without. The 90
degree fitting make lubing a piece o cake. I also got a $12
pneumatic grease gun from Harbor.  ...   :D
Joe
Kind of similar in topic, but what type of grease should you use to top off the joints? It's time to do it, and I searched and couldn't find a definite answer. I'm looking for the genuine GM grease part number. I assume it's the same grease for all 11 or so fittings?
Thanks.
I use mobil 1 grease.  Pretty inexpensive also like $3.99 a tube
I don't know the GM P/N, but it should be in the owners manual, under the table that lists all the lubricants to use.  It will be called chassis grease (or maybe lube, can't remember which).
I was just thinking about that straight zerk fitting. Can't you get on it with the grease gun if the gun has a flexible hose on it? From the picture, it looks like you'd have enough room. No? I'm just trying to figure out if I "have" to change it, or if I'll be able to get on it. All my grease guns have the 12" hose on it.
Thanks
you can get to it but the 90 or 45 makes it much easier.
I bought the 90 angle zerk and didn't put it in.  the stock zerk is easy to get to for me - maybe because of the lift?  I used a grease gun with a hose and pistol grip.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
