Infotainment system questions...
Hey do any of you guys have android phones that you connect with the USB connection? If so does it charge your phone while you're using it? If not then the battery could die pretty quickly if you are streaming Pandora... Sent from my SCH-I535 using Tapatalk 2
Hooked my Galaxy S4 up today via USB to charge (phone not in use, screen locked)... it's definitely a trickle charge. After about 15 mins, phone had only gone from 4% to 8% charged.
  • Replies 95
USB ports charge slower which is expected. The generally only put out about 500mA where a regular wall charger is normally 900mA at a minimum. I'm just glad to hear it's charging! :D
Has anyone heard how we are supposed to get map updates and system updates for the infotainment system?
GMNAVDISC.com is where the map updates will be purchased, most likely will be an SD card
"Only $199.99" for a map update if you have a 2012 truck or older... that seems reasonable :bs::puke:
I think those were DVD based. I was curious about these since they are hard drive based. I guess I was hoping since they could be updated by using the flash drive they might offer free updates to the OS for the infotainment system at the very least...
Navigation map updates are a big cash cow for every manufacturer. GM isn't going to lower their price even if you can download the update and install it yourself.
Haha well I'll just do what I do now with my 07 trailblazer then. Use the factory 07 disc and if I have an issue I'll check Google maps on my phone...
I didn't tell you to buy that POS radio, just supplying the info that was asked
Chill out man. My disgust is with OEM price gouging, not you.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
