Ok sounds good just gotta figure out if I really need the second set. I have a tono cover am not sure if one set will do it. I don't need it to be lit up like the 4th of July but I'd like enough light to be able to see to the front
I would say just get the second set, you can't regret having the extra light back there, but its easy to get feel like you don't have enough light. Plus the more spots that you have light coming from the better. You could need something from the front and the light could be blocked by something in the bed thats between the lights in the rear and the object you need.
I know I'm glad I added a second set! 1 set was enough when I still had the bare bed and the light reflected very well off of the white diamond painted bed but after any liner is placed in the bed, the extra light helps alot
Thanks for the recommendation! I think I'll order the second set here soon first set should be here by the end of the week along with my kicker audio upgrade!
Has anybody tried wiring led cargo lights to brake lights while still leaving them on switch in cab? Is it possible or even to add a switch at rear of truck to turn them all on
My question would be "Why"? I would not wire up lights to have 2 power sources... but I don't understand the reason for power from brake lights...
Instead of going into cab all the time to turn it on I could just hit lock unlock on fob and lights would go on in box
Well, I added the second set yesterday.
Noticed a couple of items. I ended up having to mount them slightly lower than the factory lights due to drill bit access to the bed wall. The rail prevented me from drilling as high as I wanted to. I used the provided inserts rather than just throwing a couple of sheet metal screws in there. That was most of the work. They work fine and add the light right where I want it. I have the harness plug end available if anyone needs it.
Where did you connect them to power the lights?
This was a second set so I just spliced the wires into the existing leads, one on each side of the truck.
Edited by rmart
Here you go...
Block8Head,
Thank you very much for posting the instructions. They were great help! Amazing how the kit does not seem to come with the instructions.
After completing the job, I realized a couple of things:
1) I should keep the tail gate locked, for it is too easy to remove the tail light lenses.
2) I'm really liking my 2014 Silverado!
I would post pics, but I am not allowed (too new I guess). :nopity: :nonod::happysad::thumbs:
Edited by GerryLP
Don't break those plastic stop light retainer clips.
$12 a pop
Don't ask how I know. :(
No Tyme, I surely would guess so. Perhaps a bad habit from my old truck.
Horacio, thanks for the heads-up. The passenger side bottom one did not want to pop out. I sprayed a little WD-40 to help it along. Luckily, I did not lose $12 today. Lol
GerryLP :cool:
I couldn't believe my ears when the parts guy told me how much they cost. I was ready for $5, not $12. I thought to myself, GM seems to have adopted European car parts pricing...a$$h@les!
Your tailgate is pretty expensive too. I advise one of these for some extra assurance.
I am not affiliated with this company or anyone who may work there or sell the product.
http://www.jimmijammer.com/product,%20gk.htm
They have dealers here in NM. I'll look tomorrow. Thanks for the tip!
GerryLP :cool:
Edited by GerryLP
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 657 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
