Just got a set of the OEM lights 20979073 for my 2014 Silverado.
My truck came with a set from the factory , but I wanted to add the extra 2 like everyone else has done .
I don't see the place to mount the extra 2 in the bed .
There are no spots to screw them in , unless I make spots
Any ideas ?
Any ideas ?
When I put a second set in I just measured a good distance between the two drilled some holes put some plastic clips for the screws bolted them up
Edited by Codman67
9 minutes ago, Todd1982 said:
Any pictures of the clips you used or what you did ?
Thanks
Sorry don’t have any pics did this a few yrs ago now but your new set of lights came with screws I just took one into my local auto place match the screw to a clip route the wire loom under the rails with clips so everything looked factory
Thanks
My kit came with the clips for the wires .
I am mostly concerned with how to attach the lights to the bed .
Drill holes ?
I used the square plastic license plate screw holders.
Drill holes ?
Mark where you wanna drill into the box just make your you don’t drill thru the outer box their is a bit of a gap between the two just careful
Drill holes ?
There are no other factory locations for the lights if you have the "short" or "standard" bed (they are only supposed to have 2 lights).  The kit should have come with self-tapping screws.  I just held the new lights where I wanted them up under the rail and used a cordless drill with a nut driver to run the screws in (stop before they go all the way then finish the tightening by hand or you will crack the plastic tangs on the housing).  After that just run the wire loom from each light back toward the existing lights and splice the wires together.
  • 1 year later...
  • 1 year later...
On 1/19/2021 at 9:50 PM, G Cumbest said:
Does anybody on here have an 8 PIN connector left over they would like to sell? I got the 6 PIN with the kit I purchased and I need an 8.
The six pin for the '16 and up harness with both Stop Light and Cargo light wires is back in stock on Amazon: https://www.amazon.com/dp/B07C488SBN
The 8 pin harness is available on ebay.  User mtushmoo
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 892 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
