My stock block is 2". Still have it for some reason :lol:
Sent from my SGH-I927 using Tapatalk 2
  • Replies 81
Your right, I just went out and measured mine. Right about 2".
Don't worry, your not alone. I have the stock blocks, 3" blocks from my level kit, and 6" blocks from my lift kit. I currently have 5" blocks installed on my truck haha
I also have 2500HD torsion keys, stock keys from my truck, and level keys
Yea mine is a 2.5" leveling kit, 3" blocks, and a 1.5" body lift
I had 305 70r16s (33" x 12") when I was running my stock tires and they fit just fine. Now I'm running 285 60r18 nitto terra grapplers (31.5" x 11") since I went with an 18x9 wheel with a lot of negative offset. If you stay with stock wheels or something with similar offset as stock 33s will fit all day just fine
What happened to the center caps on your wheels?
Managed to get the wheels and tires used from a friend for a damn good deal. He didn't have the center caps anymore so I've gotta order some sooner or later
and 99chevy323 here's you a pic of mine on 33x12s for reference
Use this calculator to figure out every metric tire size in standard measurements:
http://tire-size-conversion.com/
And like I stated before, NO you do not need to regear. It is not worth the money. Just get a good tune, and you will have even more power than stock, but with stock gears
Like he said use the calculater. 305 is the width not the height. And no I didn't regear since I have 3.73s from the factory. They work great up to a 33 imo
Do em together. You can go on performance accessories website and buy a PLS kit that comes with both. I personally did the rough country level and wanted it higher so got the body lift from zone offroad a year later.
