Gas grade? Gmt 900 2011 5.3
  • Replies 37
My LC9 runs like a slug if I don't run good premium in it and Techron it every 3000 miles. Maybe because the cylinders are sludged up and the plugs fouled from the infamous AFM oil usage problem?
Hi Guys, I'm just trading my 2010 6.2 for a new 2013 6.2, for the 200,000 klms I've done on the 2010 I've used 87 exclusively and get around 15.5 ltr/100 klms (15.1 mpg US) the 6.2 does not have AFM, anyone have any idea whether the economy would improve significantly going to 91+ most of my driving is highway on cruise control
You would see an improvement as the 6.2L recommends Premium fuel.
It very well might. Best thing to do is to try running premium for a month then see of the results are vastly different. It may be worth waiting a bit until the engine is broken in though.
Well that midgrade sure does help, when AFM kicks in does not feel like its going to die. It feels more fluid. Now i just need to hunt down this Techron everyone says to use every oil change.
It is Chevron Techron Fuel System cleaner. Available around here at Wal-Mart and the auto supply stores (Advance, O'Reilly's, Autozone, etc.) GM sells it as GM Fuel System cleaner--same stuff.
I use 87 octane from Chevy with seafoam treaments in-between on all three trucks and never had a problem. I think top tier gas is the way to go, some people swear by AM/PM or costco gas, but not for me.
Seems like every time I would get gas at either a Martins or an Exxon the truck would run kind of crappy. Seems to do fine on Sunoco, Hess, and Shell.
If you watch Orielly's they run the Chevron Techron on sale at times, I only 89 in my truck but for some reason it is a turd as gas mileage. Last trip running 70mph on the highway I only averaged 16.29 (hand calculated). So right now plugs and O2 sensors are on the way in and I will prob see about get a tune from Blackbear once I get some headers lined up.
We only have 91 in my market, one store 25 miles away from me sells 93 at the cost of $4.50 per gallon compaired to 91 at $3.60.
I am going to try runing 89 for a month and see what happens. Right now i run 87 an average 15.8mpg. Let you know in a month.
Does anyone know if the current GMT900 engines can re-adust themselves automatically on the fly, to changes in fuel octane rating - both switching to higher octane or going back to lower octane, without the need for us to pull fuses to the PCM or disconnect the battery to force the PCM to re-learn and reset to the changed octane?
This is a big deal on the Camaro forums. They call it "Pulling fuses numbers 5 and 20." Camaros will recognize low octane gas and reset the timing advance tables to a lesser (read- lower performance) version and then you begin suffering lower performance. But- they cannot reset themselves to make use of high octane without first pulling the fuses to reset the timing tables. To fix this you pull the 2 above numbered fuses (underhood) for an hour or so and fill up with highest octane gas, then next start up, the PCM will begin using the Hi-Perf timing tables.
I know Ryan or someone will have a better understanding and info than me so maybe you could translate for us Ryan. If we all want to begin using 89 oct mid range gas, will the PCM recognize it without problems? Or is there a truck equivalent to pulling numbers 5 & 20 fuses to force the reset?
Jim the Camaro people must not know how the timing map in the ECM works, pulling he fuse does nothing as GM does not use a octane sensor unless the vehicle can run E85. The Camaro is not able to run E85 from the facotry so it does not have a octane sensor.
There are 2 timing maps, a high octane map and low octane map. If the ECM sees any spark knock/detonation/KR that exceeds a certain amount of knock over a certain amount of time the ECM will drop into and use the low octane timing map, once a decay time period has passed the ECM automatically goes back up into the high octane table if there is no more knock detected.
There is no need to pull fuses, this all happends automatically in the factory calibration.
techron as montyss says, or even a can of sea foam. i have started putting that in every oil change!!
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
