Rear sliding window issues on the 2014 models
TX14Z71
I've recently noticed some unusual noises coming from my rear sliding window when I open and close it. I took a quick look and saw the visible wire that opens and closes the window, but I was unable to pinpoint the source of the noise. Any other 2014 owners that have had or are having this problem please chime in...
Hi again,
I am truly sorry to learn that you are experiencing an issue with your Silverado. I would like to learn more about your concern. Private message if I can be of any assistance.
Sincerely,
Jennifer T.
GM Customer Care
  • Replies 62
Mine is being replaced as we speak. Hope it was just a fluke thing with some initial components being faulty, and this cures it.
This issue with the slider gives me some concern. Where is GM's corporate memory? Did they fire, transfer etc. the GM folks that had to deal with the exact issue on the 900s? Or is this a low bidder supplier issue? So what else have they missed.
Did they remember the complaints on the TCM programing on the 900's. You know the drivability was so poor that folks were running to blackbear just for an 89 oct tune, not for performance but just drivability. We will see. Hope all is better as I sure do not like the Fords, Rams and for sure the Toy.
I agree, not sure how you have the same issue two generations in a row.
Mine was making loose glass noise when driving on the bumpy road with it open.. is this normal?
Probably not, I'd bug the dealer if I were you.
i did,
they scheduled me for next tuesday on the BSM recall, the rear window noise and couple minor things that they need to replace it...
Looks like everything but the window was replaced. Super quiet now, moreso than even when it was new. If I have any more issues, I'll let you all know.
i did,
BSM Recall? What is that?
Mike
Mine is the same. Better than new.
Mike
i'll get you the info this Tuesday when the truck is in for the reflash... ;)
I meant BCM not BSM.. LOL my phone keyboard sucks for typing.. :D
  • 3 weeks later...
It seemed like it was taking an inordinate amount of time to get the parts in for my window, so I called the dealership yesterday to see what is up. They said they've had the part, but for whatever reason they just didn't call me. :banghead:
All American Chevrolet service department in Killeen, TX does not impress. But I have an appointment on Friday to go in and get the parts replaced.
Drag along a cold 18 pack of good suds and give to the service MGR for the service troops after work. That should help future memory problems in service.
Hello,
Oh no! I am truly sorry to learn that you are frustrated with the lack of communication between you and your dealership. We strive to make sure that your experience with the dealership is the best experience possible. Please private message me if I can be of any assistance.
Sincerely,
Jennifer T.
GM Customer Care
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,060 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
