Anyone have Chevy 18" GMT900 Z71 wheels on a GMC GMT900 Sierra
6Sixathome
I'm thinking of putting a set of 2013 Chevy 18" Z71 wheels on my 2008 Sierra, with GMC center caps in place of the Chevy ones. My stock 17's are starting to show their age. Wondering if anyone has this combo and maybe a few pics to help me make up my mind. Here is a ebay link to the caps I would get.
http://www.ebay.com/itm/New-GMC-Sierra-Yukon-Center-Caps-Set-of-4-for-18-in-or-20-in-Z71-Wheels-Rims-/221250314433?pt=Motors_Car_Truck_Parts_Accessories&hash=item33838be0c1&vxp=mtr
I've seen it done a few times on GMFS. It looks the same as the chevy still just different center cap. Go for it.
I ordered the GMC center caps for the Chevy Z71 wheels that I have. They are replica of coarse, almost the quality of the Chevy center caps. The GMC ones are a stick on center piece and the Chevy ones are painted but the stick on GMC ones look like decent quality, time will tell how we'll they hold up. Here is a couple teaser pics until I get a chance to install the wheels on my Sierra.
They do look good on the truck. How are the center caps holding up?, any issue with discoloration, the decal coming off, etc. thanks.
Well I put the wheels on today. Before and after pics. I think they look good except for the dirty truck :-(
No problems with my center caps. They still look like new. I had the same concerns and will watch how they last through the winter.
Sent from my Nexus 7 using Tapatalk 4
I agree and will be watching through the winter as well, although they should be ok I would think. rusty503, how long have you had yours and did you buy them off of ebay?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
