Tow Mirrors
Braaap60
  • Replies 534
How are you still liking these I need to either order these or get the Oem tow mirrors for a crap load more can't make up my mind. I can't see around my trailer at all though
Although they're more expensive, the OEM mirrors are the clear winner (no pun intended). They are rock solid (no vibration) and look great on the truck. All of the aftermarket mirrors I've seen are significantly more flimsy than stock and a lot of them just look cheap.
I know I know but why dO they got to be so expensive lol
So has anyone found out if it is possible to make the led turn signal work on the Oem mirrors if mine didn't have it
I think you'd have to either locate the factory wire loom with that feature wired in, from a truck with signals, or make a wire to that pin and tap off of the turn signal wire under the dash. The latter is going to be the route I am going to go, unless by the time I swap, eta unknown, the wire loom is an easy cheap swap. I think someone had them done at the dealer and they swapped the wire loom. Somewhere in this thread. Hopefully someone else can chime in on that.
http://www.ebay.com/itm/Side-View-Mirrors-Power-Heated-Towing-Black-LH-RH-Pair-Set-for-07-14-Chevy-GMC-/281319580819?pt=Motors_Car_Truck_Parts_Accessories&hash=item417ff42493&vxp=mtr
I think these are the right ones. I am going to have them smoothed and color matched. Now the question is? What are the wire looms for signals. Any one have insight on that...
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 1,172 Guests (See full list)
