AMSOIL long live gear lube vs Severe gear formula.
I did a search on this topic & found a few threads about the subject but none of the threads asnwers this question:
Most guys are recommending the Severe gear oil. I never tow anything, nor do I haul anything heavy in my 2004 Silverado 4X4. Do I need the Severe gear or can I use the 75w-90 long life formula.
normal day to day driving you should be fine with the 75W-90 synthetic
jwalker, AMSOIL recommends the Severe Gear first and the Long Life second. The Long Life fluid would provide great protection in your differential since you do not do any hauling or towing. It would make the most economic sense in your case. I would go with the Long Life, it will provide all the protection you will need, no problem. :)
I have used the Severe Gear in both 75w90 and 75w140 in various applications. It is a very good gear lube. You can leave it in there for at least double the recommended interval with no problems. The long life is not a bad oil for sure. If it will survive 500,000 miles recommended change interval in a class 8 commercial semi, it will do fine in your pickup. The best option, by far, is the Severe Gear offering. But I would not down Mobil 1 and their 75w90 offering, as it is a pretty good product. Recently, I have grown fond of the Schaeffer Oil 75w90 #741 gear lube. One thing for certain, there are a lot of good products available. Find one that helps you sleep well at night and go for it.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
