2004 Silverado 8.1L motor flush?
My friend who is really familiar with this engine (he ran them in his boat) and knows a lot more about cars than I do keeps telling me that he hears a sticky lifter when the truck is first turned on after sitting overnight. I dont know what it sounds like so I cannot pick it up.
He says it goes away after a few minutes.
He suggested adding a motor flush in it before the oil change and run it for 20 minutes then drain and cheap oil run for a short time and then go back to my mobil 1 that I have been using for a few years now.
Any thoughts?
If you have run Mobil 1 or any good oil and change it on a regular basis you should have zero oil sludge in your motor. Here is my story, I bought a 1995 Camaro z28 brand new changed oil regularly with a synthetic, at about 20k I put a supercharger on it, and at around 114,000 my FMU when bad and I cracked #1&7 ring lands. I thought I would have to bore the motor .30 over and the regular stuff. Well pulled the motor apart and the motor had no sludge and even had the factory hash marks. All we had to do is hone the bores and slap in new pistons and basically button up the motor. Long story short, if you have changed your motor oil on a regular basis with a quality oil you will never have to do a "motor flush". Just my two cents.
i bought the truck with 89k miles on it so I dont know what its like beforehand. I have always used mobil1 full syn. He has told me he heard this lifter back when I bought it about 4 years ago. I do not drive the truck very much and have only put 8-9k miles on it since I bought it. My neighbor uses it to tow his boat as well.
Since I do not drive it very much I only change the oil about every 6 months. Cause the mobil 1 you can go longer between changes.
does the mobil 1 clean out existing gunk in there?
Also should i use the mobil 1 that can go for 15k betweek changes?
"does the mobil 1 clean out existing gunk in there?"
Yes it does, no need for a flush.
I don't know why your changing the M1 after only 6 months. That is crazy but any M1 flavor will work at that interval.
DEWFPO
I would not flush it either. Some people do use additives or add stuff before they change the oil. I got my truck at 79k miles, changed it to M1, and have just let the oil and filter do their job since then.
The standard used to be change every 6 months if you don't put on many miles, but with synthetic it's not really necessary.
If I go with that Mobil1 EP thats supposed to last 15k Can I go a whole year without changing it and just top it off?
SInce the 8.1 is known to burn oil should I go with the 10w30 oil so that it doesnt burn as much?
thanks for the thoughts on the flush
Yes, I've run M1 as long as 5 years in my 8.1L SIlverado but I don't put that many miles on it and when I do run it, I run it for at least a few hours at a time so everything gets good and hot for awhile. I have not had any problems with condensation in the oil at all. I've been doing this for years in several different vehicles and have had zero issues. If you want to use less oil go with a 40 weight an not a 30 weight. The first number is the cold start weight. That does nothing for your oil consumption. I run a 0W40 or 5W40 in all my vehicles but I deal with -20F to +100F temps throughout the year.
My 8.1L is an '05 built in '04 and uses about 1 qt. per 3,000 miles (on 0W40) which isn't bad. It used a little more when I first used 5W30.
DEWFPO
I can not comment on the flush but maybe on the ticking. I also have an 8.1 and at one time had a cold tick. The ticking was the exhaust manifold leaking slightly. As the engine warmed up, the manifold expanded and the ticking went away. Both the front and rear most bolts on both the left and right side manifold were loose. I thightened all of them back up and have not had a problem since. This may not be your problem...but food for thought.
If its had even a decent oil ran in it, it should be fairly clean...if I was to consider a flush, it'd probably be AutoRX which was pretty highly regarded on Bob is the Oil Guy.
I did a UOA on Mobil1 5w30 EP from a change in my 2012...with 6500 miles on the oil, it was still considered suitable for continued use. I would probably put a year on it if it was mine.
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
    • I bought the truck new in December 2022, and it's got 60,000 miles. The front cover magnet had slightly more glitter, but overall very clean, no off odor, and good-colored; really nothing to report. My truck has Hi-Lo transfer case, and the fluid looked great, as well. I have towed..maybe 1,000 miles. Yes, this was the first change for all three driveline items. I'll probably do the transmission at next oil change.
