Finally got my 6.2! Same options as my old 2014 5.3 besides the 6.2 obviously, and SEY 22s, but no rear slide!
Iridium, SLT, Heated/cooled jet black leather, sunroof, lane departure/collision alert, nav., 3:42s
New and old
There was no way I letting the dealer run it through their touch wash and grease it all up so its dirty in the first picture from transport, below is after I got it home and washed and waxed on my own.
Edited by jomuehlbauer
My truck was built back at the end of the summer, hence no side steps on the corners of the bumper. Which I am okay with as I didn't like it as much, plus I don't need that option. The truck I have is the SLE edition of the AT. If those are the SLT wheels then what do AT wheels look like?
these are the all terrain wheels. I just copied this pic from some vehicle on autotrader. but these are the standard wheels that your suppose to get when you get an all terrain unless your dealer is willing to swap them out with some other wheels (which happens) or you upgrade to the 20" all terrain wheels.
Edited by thewhitestallion
Just picked my 1500 up on Saturday and my parents picked their 2500 up last Wednesday. I came from driving a 1998 Silverado so comparing the new to old isn't even realistic.
Edited by softail_silverado
Fabtech 4" lift, 295/60/20 trail grapplers on 20" BMF REPR's and debadged, still debating on replacing the chrome window sill trim with black and maybe mirror caps too, I'm gonna leave the handles chrome. I'm also painting the fender plastic pieces to match.
Edited by brettls1
  • Like 7
umadany5.jpgvabarymy.jpgy3a9yja8.jpgy4evebag.jpgeba8urur.jpg2yhy9u2a.jpgu4uteju7.jpgere4e9uj.jpg
2014 silverado crew cab WT
1 5/8" spacer on top of strut
Fuel hostage 20x10 with Falken Wild peak 305/55/20
Cheap 3" step from eBay and bed rug
55watt Kensun hid 5000k kit
Interior footwell lights
Step lights
Led reverse, cargo, and licence plate lights
Rear bumper step led light
Maxfloormats
Dee Zee tailgate down assit
Plasti dip name and badges
$50 seat covers.
Wicked Galaxy Note 3
Edited by NitroDatsik
And you spliced that all into the stock wiring in the respective locations? If you have separate thread, point me in the direction. What kind of step lights and reverse lights you have there?
Sent from my DROID RAZR HD
Interior Lighting Fuse
http://www.gm-trucks.com/forums/index.php?/topic/158559-Interior-Lighting-Fuse
Follow that ^^^¡ thread for the step and interior lights. You'll need some extra wire to run the step and footwell lights. The ones on the rear bumper are long enough, tap those into the led red wire into green wire of each one of the reverse tail light and a self tapping screw for ground.
Interior + rear bumper light
Jorge Rangel wants you to see this item at Amazon.com
Universal 6pcs High Power White 3w LED Eagle Eye Bumper DRL Fog Lig... http://www.amazon.com/dp/B00FEZEVQK/ref=cm_sw_r_udp_awd_9Gnetb162K2WQ
Step light
4 Pcs 30cm Car Truck Flexible Waterproof LED Light Strip White (White) by Generic http://www.amazon.com/dp/B00EXGRRJE/ref=cm_sw_r_udp_awd_sInetb15EE7MC
Reverse tail light led
iJDMTOY Extremely Bright 7.5W High Power 912 921 LED Reverse Light Bulbs, Xenon White by iJDMTOY http://www.amazon.com/dp/B008G4Y076/ref=cm_sw_r_udp_awd_zJnetb03XASG6
Z71 Double Cab.
(I do however miss the suicide door of my 2010 extended cab)
Not much done other than a Curt front receiver.
Not too many clean trucks here in the snowy north east right now. :)
Been holding off posting pics until I got my leveling kit and tires installed. Love it!
  • Like 6
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,532 Guests (See full list)
    • I have 2 choices.
