Finally got my 6.2! Same options as my old 2014 5.3 besides the 6.2 obviously, and SEY 22s, but no rear slide!
Iridium, SLT, Heated/cooled jet black leather, sunroof, lane departure/collision alert, nav., 3:42s
New and old
There was no way I letting the dealer run it through their touch wash and grease it all up so its dirty in the first picture from transport, below is after I got it home and washed and waxed on my own.
Edited by jomuehlbauer
My truck was built back at the end of the summer, hence no side steps on the corners of the bumper. Which I am okay with as I didn't like it as much, plus I don't need that option. The truck I have is the SLE edition of the AT. If those are the SLT wheels then what do AT wheels look like?
these are the all terrain wheels. I just copied this pic from some vehicle on autotrader. but these are the standard wheels that your suppose to get when you get an all terrain unless your dealer is willing to swap them out with some other wheels (which happens) or you upgrade to the 20" all terrain wheels.
Edited by thewhitestallion
Just picked my 1500 up on Saturday and my parents picked their 2500 up last Wednesday. I came from driving a 1998 Silverado so comparing the new to old isn't even realistic.
Edited by softail_silverado
Fabtech 4" lift, 295/60/20 trail grapplers on 20" BMF REPR's and debadged, still debating on replacing the chrome window sill trim with black and maybe mirror caps too, I'm gonna leave the handles chrome. I'm also painting the fender plastic pieces to match.
Edited by brettls1
  • Like 7
umadany5.jpgvabarymy.jpgy3a9yja8.jpgy4evebag.jpgeba8urur.jpg2yhy9u2a.jpgu4uteju7.jpgere4e9uj.jpg
2014 silverado crew cab WT
1 5/8" spacer on top of strut
Fuel hostage 20x10 with Falken Wild peak 305/55/20
Cheap 3" step from eBay and bed rug
55watt Kensun hid 5000k kit
Interior footwell lights
Step lights
Led reverse, cargo, and licence plate lights
Rear bumper step led light
Maxfloormats
Dee Zee tailgate down assit
Plasti dip name and badges
$50 seat covers.
Wicked Galaxy Note 3
Edited by NitroDatsik
And you spliced that all into the stock wiring in the respective locations? If you have separate thread, point me in the direction. What kind of step lights and reverse lights you have there?
Sent from my DROID RAZR HD
Interior Lighting Fuse
http://www.gm-trucks.com/forums/index.php?/topic/158559-Interior-Lighting-Fuse
Follow that ^^^¡ thread for the step and interior lights. You'll need some extra wire to run the step and footwell lights. The ones on the rear bumper are long enough, tap those into the led red wire into green wire of each one of the reverse tail light and a self tapping screw for ground.
Interior + rear bumper light
Jorge Rangel wants you to see this item at Amazon.com
Universal 6pcs High Power White 3w LED Eagle Eye Bumper DRL Fog Lig... http://www.amazon.com/dp/B00FEZEVQK/ref=cm_sw_r_udp_awd_9Gnetb162K2WQ
Step light
4 Pcs 30cm Car Truck Flexible Waterproof LED Light Strip White (White) by Generic http://www.amazon.com/dp/B00EXGRRJE/ref=cm_sw_r_udp_awd_sInetb15EE7MC
Reverse tail light led
iJDMTOY Extremely Bright 7.5W High Power 912 921 LED Reverse Light Bulbs, Xenon White by iJDMTOY http://www.amazon.com/dp/B008G4Y076/ref=cm_sw_r_udp_awd_zJnetb03XASG6
Z71 Double Cab.
(I do however miss the suicide door of my 2010 extended cab)
Not much done other than a Curt front receiver.
Not too many clean trucks here in the snowy north east right now. :)
Been holding off posting pics until I got my leveling kit and tires installed. Love it!
  • Like 6
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 476 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
