2015 GMC Sierra 5.3L 4x4 sle
2006 GMC Sierra 4.3L 2wd wt
A buddy just picked up an old-man special - 2003 Silverado with 85K on it.
It is interesting how much bigger these seem next to an older one. I did like my 2001, but this 2015 is oranges to it.
I got 305/55R20 cause the 285's were backordered. They do rub a little bit on the upper control arm at full lock, but I just avoid cranking the wheel that far and nobody seems to notice.
They look bigger... If you had a +20 offset wheel, think they would hit/rub?
Will be color matching grille and headlights monday
My contribution ...
Very clean. I see yoy removed side moldings. I have the same truck and am thinking of leaving those on but removing the All Terrain badges....now to look at your picture further.
Sent from my iPhone
Do those duratracs make much noise on the highway? Sound like an all terrain tire or mud terrain?
Looks awesome man! What are the tire/lift specs?
Readylift SST 4" with uniball UCA's. Rancho XL9000's on all 4 corners. 20x9 w/ 27mm offset wheels with 35x12.50R20 Toyo M/T's.
I don't think they would rub with that offset
They do make some noise, but coming from Mickey Thompson MTZ and BFG mud terrain tires before these, these are very quiet. Even with almost 30,000 KM's on them
Sent from my iPhone
Thanks.
I've been toying with the idea of removing the AT badges. The mirror caps and door handles will be changed to Iridium and the belt moldings will be changed to black.
Thanks.
Painting the belt moldings?? Or is there a direct replacement?
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,300 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
