Figured I'd throw up a pic right after finishing a complete 2 day detail with Adams Polishes. Great stuff!
I highly recommend it. :thumbs:
0642695D-D817-4F7F-B65B-13FC70F5FCDA_zps
Well done, one of the nicest trucks I've seen. What are the specs?
Thanks much Sean.
Specs:
6" BDS Lift, Fox 2.5 DSC Coil-Overs, BDS Glide-Ride springs, Zone 1.5" Body Lift,
DPR Offroad Stealth 20x10, -12 offset with 35x12.50 Toyo R/T's, AMP's
Yukon 4.10's, aFe Power catback, Airaid Jr, Diablo Tune, All Recon
Edited by Cato
With the Glide-Ride springs, did they install with the stock blocks or did BDS supply a replacement block? Also with those springs does your truck sit below level, level or higher in rear than front?
Thanks much Sean.
Specs:
Thanks much Sean.
Specs:
Nice. Waiting for my 7-9 kit, 20x10's and toyo rt's.. thinking about upgrading the kit to coil overs as well, but can't figure out what size, or how to get them. I'm assuming you added the 1.5 BL because you rubbed with the 6" kit, I'm going with the same wheel/tire combo as you, will the lift set at 7 rub?
When I leveled my truck I swapped out the stock rear blocks with ReadyLift 2" blocks to maintain some rake. I used those 2" blocks in place of the stock blocks with the Glide ride springs for the same purpose. Rear end sits prob 1.5" higher than the front. BDS doesn't supply the blocks with the springs as they typically have you reuse the stockers.
Yup. Had slight rub at full crank in reverse. Not bad but annoying none the less. The BL did the trick. At 7" you may be close as my shop told me that trucks with the coil over kits typically sit a bit higher than the lift specs note. I was hopeful but no dice for me.
8" would be a safer bet I'm thinking if you only want to do it once. 7" may be a close gamble.
Mine rubbed at rear of front fender wells and not just the plastic. Would've had to trim sheet metal which I didn't want to do.
Edited by Cato
Thanks for the info, I'm trying to set this up so I get the look I want, and still be able to pull through a 7' door. I think at 8" I will be rubbing the ceiling. This is gonna be tight. Any chance you have photos before you did the flares? You can text, or email if it's easier. Thank you,
Sean
[email protected]
(941)809-9274
Man, you sure do like to posts a lot of pics of your truck. Your obsessive pride us noted. Good looking rig.
Sent from my QTAQZ3 using Tapatalk
Sean
[email protected]
(941)809-9274
Unfortunately I don't have pics without the flairs with the lift and wheels as they were installed at the same time. Sorry man.
New Access cover today!!
Is that the Lorado? Reason I ask is that mine seems to be a bit long from left to right where it's hard to keep it tight... But yours seems a lot less.. Especially drivers side back corner just to the right of the Z71 decal... That almost looks short... I know the access' have adjusters but I just haven't messed with them yet... Been 18 months and love it...
No, it is the original.
Jon I feel ya man. She's is only 14 months old and already has over 21k miles on her. I just love driving her everywhere!! Fun as hell. lol
Nice! ive just rolled over 22k in just over 7 months? haha so comfortable.
Most of my mods complete now, been a busy week:
Nfab Nerf Bars
black out front bow tie
removed silverado letters and put Z71 emblem on side
removed Z71 decal off rear fender
removed rear bow tie & LT
Installed Weathertech window vents & floor mats
Waiting on bakflip MX4
Edited by jdurhan
Holy crap! Rock on buddy!
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,829 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
