Finally got around to getting my wheels and tires installed. 20x10 fuel hostage with a -24mm offset. Tires are Toyo Open Country AT 2 at 305/50r20. Went with these because they are only 50ish pounds a piece compared to around 70 pounds for a 305/55. Don't mind the filthy truck. Getting a lot of rain as of late.
What offset, and more pics please. Been looking at x10s and just bought 305/50s about a month ago so this will give me a good idea where i'd be at. thanks.
Haggled a guy on CL for his set of Tahoe wheels and slapped my BF Goodrich's on them. Love the look, and am happy I achieved the look I was going for without having to do aftermarket wheels.
what the difference between the tahoe wheels and that style silverado wheels?
No difference other than the color. I think all Z71 LT models got the same style wheel, but it looks like they only did this style with this color for the Tahoe's.
Truck is currently getting detailed and then Line x, so I cannot add more pictures for a couple days. I have some from the day they were installed. The offset is -24mm.
Edited by Schmidt0221
Looks awesome, thanks. I have the rear block in so I may not rub with -24. Still probably will look at the -12 or -19 offset wheels I've been considering .
Edited by techsan15
Removed the air dam this evening. Plan to get the Mazzulla skid plate and bar once it's available at SDHQ
  • Like 3
Looks sharp.
Is that off Gilbert Road? I think I live very close to you lol. I'm off the 202 and Gilbert in Mesa
Edited by TheArizonaPatriot
I called Mazzulla on that skid plate, and in order to use it, you have to cut the tow hooks and horseshoe knuckles off to make it fit. Man, I wish there was another option out there. I really don't want to do something that evasive to my truck...
The tow hooks can be removed and the knuckles serve no purpose after assembly. I say go for it! That skid plate is awesome...
Call Gunnell's Tire & Auto (480) 844-1090 and ask for Ryan. He can take care of everything if you choose to go that route.
SWEET! Is your truck black or tungsten?
All these blacked out 2016s make me want one!
/quote]
Looks great. What size tires are you running? Do you have a level installed?
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
