Here is my 2015 GMC Sierra SLT 6.2 Stone Blue Metallic post-161511-147120023145_thumb.jpg
Edited by CUL8R
  • Like 4
I love this truck.. So much win! I have the same color-ish on the Silverado
What suspension/level set up are you running? I've been looking at 20x10s wrapped in some 305s but everyone is telling me it won't work with a level
Sent from my XT1254 using Tapatalk
I am running the 2.5" rough country leveling kit. I didn't install the rear part of the leveling kit that came with it, just the front. There is a SLIGHT rub when backing up at full crank. However, I did not have time for an alignment, so once aligned that should help out a little bit.
Finally got around to getting my wheels and tires installed. 20x10 fuel hostage with a -24mm offset. Tires are Toyo Open Country AT 2 at 305/50r20. Went with these because they are only 50ish pounds a piece compared to around 70 pounds for a 305/55. Don't mind the filthy truck. Getting a lot of rain as of late.
Looks great, love the width and poke.
Sent from my SM-G930V using Tapatalk
Thank you
Back before the most recent changes..
ced42caf-6237-4e45-8947-b4c7ef11cd5b_zps
Looks like your truck has a mustache. :)
Fremont CA. mornings. Getting ready to de-badge the truck
Haggled a guy on CL for his set of Tahoe wheels and slapped my BF Goodrich's on them. Love the look, and am happy I achieved the look I was going for without having to do aftermarket wheels.
Edited by Timmyboy188
  • Like 4
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 608 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
