Hello,
New to this forum.
Here is my 2015 Silverado LT. Crew Cab.
Great looking truck man! Just front level? what is the tint setup?
Yes, just a 3" inch spindle up front, limo front sides, limo tint visor on windshield and limo over the darkened rear sides and back windows.
Beautiful summer day took 2 quick phone pics0dc592348e042e72849eca6e67c3d3c8.jpgf7d2e7fad23d9f432c08d3a8f6c4fde6.jpg
You took a full size on the Alpine Loop? Yikes. I like to take mine in the mountains but I'm not that brave! Ha.
I did, the lower part off 550 was by far the worst and more than I wanted to do with my truck, I think they over shot the medium trail difficulty level on that part because everything I read said a stock good clearance 4wd shouldn't have a problem. I guess they were mostly right as I made it without new damage and only a few bumps; the rest was pretty easy though. Only hit my frame twice and rear axle once (in the lower section), never the nose or rear. Cinnamon was easier of the two. I hear you can pick up the Alpine loop at a different spot and avoid that rock quarry I drove through, that would make the rest easily doable in a full size with 4wd.
I think next time I will try Yankee Boy, might be a while before I get up there though.
Tyler
Just put these ON!
Havok H109 20x9 -12
Nitto Ridge grapplers LT295/55/20
Returning member after a few years truckless. Here's my new ride:
2017 GMC SLT Premium Plus
6.2 L
2.5" RC Level
20 x 9 + 1 Fuel Maverick
295/55r20 Nitto Ridge Grapplers
abe5653e1f8c3c037e2132bbb95c0bbd.jpg499604c81e8db08133237dfed43a8699.jpgf391e4d1b8253f9be89c4e71e2eb2582.jpg382061d81c370c49c13403010483eee2.jpg
Good looking Truck!
Did u get any rubbing with that setup?
6.2 L
2.5" RC Level
Perfect wheel/tire combo with that level. Looks bad ass
Thanks man! It barely rubbed the wheel well liner on the driver side at full crank. It rubbed right where the hump is molded into the liner out so I just trimmed out the bottom of the hump.
Thanks brother! I think it's got just the right amount of stance.
My 2017 2500HD Duramax Z71 Midnight edition
Envoyé de mon iPad en utilisant Tapatalk
anymore pics of you Truck love midnight Duramax
Where did u get the hood?? That looks awesome!!
2015 z71 silverado
2017 silverado Z71
mods to date: GoRhino steps, tints, red powder coated tow hooks, plastidiped emblems.
I woudl like to get A/T tires same size maybe a bit wider, and a 1.5 to 2" level.
any suggestions, btw it wont let mew upload images here.
Edited by javierh41
Updated pic. RC 2.5 and 33in BFGs.
Do you think that with a 2 inch level will those tires rub?
    • I see where you’re going and I can appreciate that. Statistics can be misleading because of the word average. They say statistics show the average cost of a new vehicle is about 50k. The average monthly payment is close to 1000 dollars a month. That’s statistics for you. I know very few people who pay that.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
