2015 LT 7" lift 20x10 fuel wheels
Edited by Ryan033
Seeing a chevy in that blue makes me hate myself for getting a GMC.
Had to update my pic... clean truck and camper shell.
Twc
Edited by spenpet
2017 silverado Z71
mods to date: GoRhino steps, tints, red powder coated tow hooks, plastidiped emblems.
I woudl like to get A/T tires same size maybe a bit wider, and a 1.5 to 2" level.
any suggestions, btw it wont let mew upload images here.
I've been considering red powder coating to give it that redline look. Pics???
Some use photobucket or other host to upload pics
Sent from my SM-G955U using Tapatalk
Edited by H-Town Silver Bullet
my truck
looks good , Z71 emblems where did you find them ? bumper info Please .
Thank you. Actually, stock emblems, I just got some vinyl wrap and covered the red...it took a bit of practice, but really easier than I expected! Bumper is an Iron Cross HD Low Profile with Iron Cross fog lights, and I just ordered a light bar for the middle (a cheap one off Amazon, so we'll see how well it does).
How much more does the iron cross one weigh? I've been considering a winch mount bumper... seriously intimidated by how much it will weigh.
Just got My 2016 Silverado back a few days ago. Has BDS 4 inch lift with fox shocks in the back. Has anyone taken these trucks off road yet with this lift?
i'm not 100% sure how much it weighs, probably 60-70lbs? its light enough i could hold it by myself when my nephew was lining it up to install it, but heavy enough that i dont want to hold it all day...however, if you are worry about the weight of it creating the front end to sag, i have had mine over 6 months and havent noticed any significant issues as far as weight goes...and i am willing to bet there are a bunch of bumper that have brush guards and cattle guards that are way heavier than this one. this one is not winch mountable, but if you like the style, Iron Cross does offer one designed for a winch. good luck! post some pics if you do upgrade!
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
