Man that looks great
Thanks, and same to you! I wanted a Z71... Couldn't sell it to the wife tho :D
I was lucky mine was at work [emoji23][emoji23]
a little vinyl and a little time and you can customize that red Z! ;)
What's the specs on your truck? Thanks
Sent from my SM-G955U using Tapatalk
I was thinking about it but then I also removed those emblem and reinstalled I think I’m gonna keep them red thank you
2017 LTZ Z71 CC
20x9 fuel Savage
Falken wild peak 35/12.5 M/T
BDS 6” Lift with fox rear 2.0
Amp research power steps
GM Cool air
D badged and then Reinstalled the Z71 emblems back on the doors
This week:
Illuminated bow tie
Driver assist handle
2017 LTZ Z71 CC
20x9 fuel Savage
GM Cool air
This week:
Illuminated bow tie
What's the offset on your 20x9's and how many lugs worth of tire are outboard of your fender? Do you have a pic straight down the side of your truck from the front corner?
Looking to run a 6" lift and 35's but trying to keep as much tire under the truck as possible to avoid needing fender flares. Local shop said the best I could do is run a 9" wide wheel with a high positive offset. So I'm curious/excited to know your results since your setup seems similar to what I would run
I forgot what the offset was I’ll get a hold of my buddy at SoCal super trucks and find out what it was and when I get to my other shop I’ll take some pictures for you
Thank you very much!!!
Just got my 2017 GMC Sierra 1500 CC Base trim. Looking at getting new wheels and tires. What is the biggest wheel/tire i can do with or without a 2 inch level. Looking at getting Toyo Open Country C-T. Thank you
I think! 275/55r20, maybe a little wider
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
