Thanks!
They are DeeZee NXT boards. I like them a lot. They are aluminum so rust won't be an issue and they don't flex a bit with my 170lbs on them. They are worth every penny just to protect the paint from rock chips. I added some flaps at the front to protect the the doors and some filler pieces along the back side to fill the gap between the boards and rocker panels.
187AAC92-A0FD-4926-915E-99B922E2A3CA_zps
Another question !! is the lower balance of your bumper custom ?? i really want to get rid of the chrome and plastic balance..
on another note i went with the GoRhino steps similar to yours.
Sent from my SAMSUNG-SM-G890A using Tapatalk
2014 GMC Sierra SLE Z71
Upgrades l have installed:
Window tint
Magnaflow dual exhaust
2.5" RC Leveling kit. Front only
275/70/R18 Toyo Open Country
Edited by KpruittZ71
  • Like 3
Window tint
That's a really clean looking rig...love those 18" Z71 rims - I think they are the best looking stockers made! I've got the same thing except white and DC. Don't know if you are a "sticker" guy, but I added the older style 2013 Z71 sticker to the back of the bed.
How does she look from the front and rear? I've run 275/70 before but in BFG KO, and found them to be narrow. The Toyos may look better though.
Edited by bcbz71
Just got her last night. New to me, but used. 2015 Z71 2LT Double Cab with only 11,000 miles. Quite the change from my 1999.
  • Like 5
Thanks man I appreciate it!
All my trucks have been Z71's, so when I got to the dealer and realized that the bed stickers are now a $100 option (not sure but I think that's for GMC's only) I was little ticked off. I will say now though that it's grown on me not having them. Also don't understand why the GMC's don't have the Z71 logo in the dash cluster.
The Toyo's are pretty much flush with the fenders. I don't really like the look of big mud flaps so I didn't want a tire that stuck out and that would totally destroy my rocker panels.
2017 All Terrain.
2" RC front level
KO2s
May add the front spacers and the rear blocks, not sure yet.
Edited by fc_glk
  • Like 3
2017 All Terrain.
2" RC front level
KO2s
It looks like it sits up there pretty good as it is to me. Nice lookin' truck!
Sent from my E6810 using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
