1 hour ago, Skidsareforkids said:
Love the wheels! I’m thinking of getting those too. How do you like them? What size of tires are those?
I went with these cuz I was tired of the chrome CK375s I had on! I love the way it looks. I just need to black out the honeycomb on the grill. I ended up getting Michelin Defenders 285/45/22 from Discount. Dealership recommended I balance them with 20lbs or less. No issues whatsoever and rides smooth.
8 hours ago, tyler.frost92 said:
what mudflaps are those?
They're made by Bulletproof Bumpers.. but the shop i deal with has them custom made with their logo on it, Farleys Truck & Auto Addictions.
CNC cut stainless steel kickback to clear larger tires, heavy duty rubber with all stainless hardware. These are the 12" wide, black powdercoat... but you can get them in plenty of different sizes.
On 2/8/2018 at 10:23 PM, Josh154 said:
285 does in fact determine height as well. Go look at 285/55, 295/55 and 305/55. Both the 295 and 305 is taller than the 285. The 305/55 comes in nearly a inch taller than 285/55.
The dimensions of a 285/65r18 tire are 11.22” wide (section width) & 32.6” tall (outside dia)
The section width is 285mm wide  (There are 25.4mm to an inch)
STEP 1) 285mm divided by 25.4” = 11.22” (section width)
STEP 2) Multiply 11.22 (section width) by .65 (aspect ratio)
11.22 x .65 = 7.29” (section height)
To find the outside diameter
Multiply 7.29 (section height) x 2 then add rim diameter
STEP 3) 7.29” x 2 =  14.58” + 18.0” = 32.58” round out to 32.6  (outside dia)
New to the forum. Here is my truck:
 2014 1500 LT "custom"
Bilstein 5100's, front on highest setting, Rough Country rear block. (removed the front spacer when adding the Bilsteins)
Fuel Titan 20x10
Nitto Ridge Grappler 33x12.50
Fuel Titan 20x10
You shouldn't be squatting with the RC block in the rear and 5100's up front. If anything the front should still be lower.
Fuel Titan 20x10
Any rubbing up front with 20x10 and 33x12.5?
5ea98284134d67d0d926b0a54cff6146.jpg0d3224a925b9f608ab4e10d61c032537.jpg 2014 Silverado 6" BDS with 35x12.5 Cooper st maxx tires and 18x9 fuel octane wheels.
I agree. I believe they left the top spacer on top of the shocks and only pulled out the bottom spacer part of the RC level kit. I had the shocks put on at the same times as the wheels. There is a little squat, this picture makes it look like there is more than it does in person.
The shop I had put the shocks and wheels on did some trimming, not sure exactly what, but even with the trimming it only rubs in reverse at almost full lock on the left. Weird, not the right but only left. And its very little. Once I get past a certain angle and get to full lock theres no rub.
Has any of you went from a Zone 4.5” lift to the 6.5”? Tossing the idea around... PFA
Fuel Titan 20x10
Is that chrome on the mirror stick on?
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
It’s just blocks and strut spacers, very easy. I did it on my ‘13
4.5" Zone
16 Silverado CCSB
-Zone 4.5" Suspension Lift
-Hostile Sprocket 20x12 -44
-AMP Attack M/T 285/55
    DM22
    DM22
  • Who's Online   6 Members, 1 Anonymous, 1,658 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
