Thank you! I had every intention of getting a white frost but fell in love with the crimson once I saw it. :)
Believe it or not they are Pilot brand I picked up at Wal-Mart for less than 9 bucks. My cargo and backup lights are JDM ASTAR that a buddy of mine recommended but they are too large for the license plates. These fit perfectly and I feel are the right amount of brightness, and hey it's Wal-Mart if they fail I'll take them back! :cheers:
Looks great! Do u have a link or specific number for the JDM reverse/cargo lights?
And nvm I see the link u posted a few pages back
Edited by cjz28
K ordered em thanks! They both say reverse lights though... That doesn't matter?
Sure thing, I think you'll be very happy! I used the 2nd ones for cargos because they are a little shorter and fit in the lamp better...the others fit well in the backup light and I feel are a little brighter. Thanks!
Sent From My Galaxy S6 Edge+
Finally got some tires on! Super stoked with how it came out. Just need to give her a bath when I get home.
  • Like 4
what tire set up did you end up going with?
295/55/20 Toyo AT2. The 305's were going to rub like crazy.
Tires look good!
Got a set of 275/55/20 duratracs on and installed airraid intake this weekend. Next up is the 2" rc level and 30 inch light bar. They are just sitting at my house need to find the time to put them on!
Too bad my truck was dirty yesterday, one of my customers sweet C10 is in the shop for a full Willwood big brake kit.
  • Like 7
Nice looking Truck!!! Where did you get the black Sierra door emblems? I have looked online and ordered some off Ebay but they are not aligned properly to "just stick on the door". Looking for Black Denali door emblems as well. Thanks!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
