2016 Chevrolet Silverado Double Cab
2" Rough Country Leveling Kit
20" +1 Offset Fuel Couplers
275/60r20 Goodyear Wrangler Duratracs (no rubbing)
Dual Side Exit Borla Touring Exhaust
K&N Blackhawk CAI
Diablo Sport Programmer
AMP Research Steps
  • Like 3
This is a stock photo from GM but it is EXACTLY my 2014 High Country in every detail. All I've done since 3/30/16 is to buy a K&N to help my baby breath better. I bought it used this past week with under 20k miles and immaculate condition throughout; and non-smoker.
Very impressed with how QUIET this truck is with DI. I can hear a little bit of the DI tick when standing outside but that is dampened with all of the work on the cyl heads and exhaust shielding. Not planning to change a whole lot.
I'll miss my 2003. It was sporty for an LS but I had made some appearance and light performance upgrades. Needed something that I could take the boss and peers out to lunch in as well as on long trips with family. REALLY wanted a crew cab and when this came up on the lot under $43K and equivalent 2016 new are listing over $57K, my decision was made.
Upgraded exhaust may be in the future but way down the road ;)
Traded in my tired 2003 Silverado sport side with its trusty 4.8L
Edited by TedH
looks good
Driving back down from Inyo mine/echo canyon
Death Valley ca
2LT - Crew Cab
Factory Running Boards
Truxedo Lopro
BFG All Terrians 275/65/18
Customized Door for Wheelchair Access
  • Like 3
Sent from my SM-N920V using Tapatalk
  • Like 9
From the other night when I installed my VLEDs! There was a heavy mist/fog that made for some pretty cool picture opportunities!
4F4F8A75-6BF9-4507-9F8A-BF500CD47F12_zps
B054DC8E-DD7A-468E-B52C-887677FC4C07_zps
Hey man nice build. Quick question, I did the same thing as you with replacing the amp step strips. Unfortunately mine look kinda purple which look horrible against the puddle lights. Do yours match?
Edited by jnach
Finally had a break from all the rain so I was able to clean my truck
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
